Installation & Licensing
Active Contributor
jason
Message 1 of 4 (435 Views)
Smoke 2013 SP 2_License error, repair needed
435 Views, 3 Replies
02-26-2013 10:55 AM
I just installed SP2 for Smoke 2013 and now it says I need to repair my license.  When I try to connect and activate, I get an error:
The system has encountered a problem. You may try again in a while, or submit this registration to Customer Service. You will receive an emailed response with your registration and activation information within 2 business days. (204)
Just last week I had some license issues converting from a network license to a standalone when install Smoke 2013, but everything was functioning fine before I installed SP2.  Perhaps its related?
Jason
TravisNave
Message 2 of 4 (425 Views)
Re: Smoke 2013 SP 2_License error, repair needed
02-26-2013 11:39 AM in reply to: jason
Most likely.  If you did a conversion the installer for the service pack may have switched it back as it was originally installed the other way.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
philip.s
Message 3 of 4 (417 Views)
02-26-2013 11:52 AM in reply to: jason
Hi Jason,
Confirming that this is related to the network to standalone licensing swap, specifically a back end systems issue that is preventing the automatic activation process from functioning properly. With that being said, I've just processed a manual activation and sent you the activation code via email and Private Message.
A workaround in this case would be to contact our License Assitance team if you ever again require a re-activation, providing your serial number + request code, and they will be able to generate an activation code.
Philip Schmelzer
Active Contributor
jason
Message 4 of 4 (412 Views)
02-26-2013 11:55 AM in reply to: philip.s
Thanks for the quick response!
All is working now...
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
