Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Smoke 2012 ADLM server won't start on Mac OSX
- Highlight
- Email to a Friend
- Report Inappropriate Content
I'm having trouble with ADLM for Autodesk Smoke 2012 for Mac OSX 10.6.7
I've installed the License Server locally and requested and installed my license.
The problem seems to be that the ADLM refuses to start.
If i use the License Server Configurator the Server Status is Stopped. If I click start, after a long pause i get:
"Unable to start the license server."
Service Monitor gives a similar result. Everythings Status is green, exept for License Server (ADLM) which has a red status circle. It is version 4.0.35. When i click Start or restart It gives the message "unable to start"
Does anyone have any advice on how to get Smoke up and running? I'll be more then happy to provide more information if needed.
Thanks for you help everyone.
Re: Smoke 2012 ADLM server won't start on Mac OSX
- Highlight
- Email to a Friend
Hi Craig.
Let's take a look at the two ADLM log files and see if there's any detail on what prevents ADLM from running.
Please open the Terminal app from /Applications/Utilities and then type:
cat /var/log/autodesk/adlm_flexnetserver.log
Take a look at the output and post any error messages you find in that file.
Then run the following command:
cat /var/log/autodesk/Adlm.log
And see if there are any error messages.
Robert.
Autodesk Flame and Smoke Customer Support
- Highlight
- Email to a Friend
Thanks for the quick response ![]()
Here are the results of the tests ordered by Dr. Robert
Using cat /var/log/autodesk/adlm_flexnetserver.log I get:
9:29:59 (lmgrd) The license server manager (lmgrd) running as root:
9:29:59 (lmgrd) This is a potential security problem
9:29:59 (lmgrd) and is not recommended.
9:29:59 (lmgrd) "Ginger-Pro-Smoke.local": Not a valid server hostname, exiting.
9:29:59 (lmgrd) Valid license server system hosts are: "Ginger_Pro_Smoke"
9:29:59 (lmgrd) Using license file "/usr/local/flexnetserver/adsk_server.lic"
using cat /var/log/autodesk/Adlm.log
i get a very long list of my fruitfuless attempts. Some common one that pop up are:
52558 2011/10/26 09:33:10 File=AdlmIntNWFBLicense.cpp,Line=766
52558 2011/10/26 09:33:10 VendorID=3 [FLEXLM-NW]
52558 2011/10/26 09:33:10 VendorError=-15 [Cannot connect to server]
52558 2011/10/26 09:33:10 FLEXLM-NW=v11.9.0.0 build 87342 x64_mac10
52558 2011/10/26 09:33:13 Reason=Fatal error
52558 2011/10/26 09:33:13 ComputerName= Ginger_Pro_Smoke
52558 2011/10/26 09:33:13 OS= Mac OS X 10.6.7 (10J869)
52558 2011/10/26 09:33:13 File=AdlmIntNWFBLicense.cpp,Line=749
52558 2011/10/26 09:33:13 AdlmIntError=20 [License check out failed]
and
17578 2011/10/25 15:37:00 File=AdlmIntNWFBLicense.cpp,Line=749
17578 2011/10/25 15:37:00 AdlmIntError=20 [License check out failed]
21444 2011/10/25 15:41:01 Reason=Fatal error
21444 2011/10/25 15:41:01 ComputerName= Ginger_Pro_Smoke
I can post the entire log if required. no worries. But it is embarrassingly long
Thanks for helping me out,
- Highlight
- Email to a Friend
Hi Craig
Looks like we're dealing with a classic case of hostname problems. ![]()
The recommended setup is to have "127.0.0.1" (your Mac's internal localhost IP) in the license server config rather than your Mac's regular network name.
To fix this issue, please try the steps described in the following Knowkedge Base article:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Please let me know if that article solved your problem.
If you encounter any other issues with Smoke, please don't hesitate to ask about them here or in the dedicated Smoke for Mac OS X forum on the AREA: http://area.autodesk.com/forum/autodesk-smoke-for-
If you want to ask the Smoke Support team a question, or give us your feedback, you can visit our Facebook page at http://www.facebook.com/AutodeskMECF
Robert.
- Highlight
- Email to a Friend
I am having the same issue getting ADLM to run.
I attempted the fix listed, and still cannot get the License server to run.
What other fixes can you offer?
I've tried uninstalling and re-installing...still no results.
Desperate here, we have a very hot project that we need to work on, but are stuck in the mud...
Thanks in advance!
- Highlight
- Email to a Friend
Hi Ksckreate.
Can you please post the output of the two logs I mentioned previously?
and
Robert.
- Highlight
- Email to a Friend
Here are the logs:
16:33:48 (lmgrd) The license server manager (lmgrd) running as root:
16:33:48 (lmgrd)This is a potential security problem
16:33:48 (lmgrd)and is not recommended.
16:33:48 (lmgrd) "Smoke-Edit-1.local": Not a valid server hostname, exiting.
16:33:48 (lmgrd) Valid license server system hosts are: "Smoke-Edit-1"
16:33:48 (lmgrd) Using license file "/usr/local/flexnetserver/adsk_server.lic"
337602011/12/0413:47:14Reason=Fatal error
337602011/12/0413:47:14ComputerName= Smoke-Edit-1
337602011/12/0413:47:14OS= Mac OS X 10.7.2 (11C74)
337602011/12/0413:47:14File=AdlmIntNWFBLicense.cpp
337602011/12/0413:47:14VendorID=3 [FLEXLM-NW]
337602011/12/0413:47:14VendorError=-96 [Server node is down or not responding]
337602011/12/0413:47:14FLEXLM-NW=v11.9.0.0 build 87342 x64_mac10
337602011/12/0413:47:23Reason=Fatal error
337602011/12/0413:47:23ComputerName= Smoke-Edit-1
337602011/12/0413:47:23OS= Mac OS X 10.7.2 (11C74)
337602011/12/0413:47:23File=AdlmIntNWFBLicense.cpp
337602011/12/0413:47:23AdlmIntError=20 [License check out failed]
337602011/12/0413:47:28Reason=Fatal error
337602011/12/0413:47:28ComputerName= Smoke-Edit-1
337602011/12/0413:47:28OS= Mac OS X 10.7.2 (11C74)
337602011/12/0413:47:28File=AdlmIntNWFBLicense.cpp
337602011/12/0413:47:28VendorID=3 [FLEXLM-NW]
337602011/12/0413:47:28VendorError=-15 [Cannot connect to server]
337602011/12/0413:47:28FLEXLM-NW=v11.9.0.0 build 87342 x64_mac10
337602011/12/0413:47:33Reason=Fatal error
337602011/12/0413:47:33ComputerName= Smoke-Edit-1
337602011/12/0413:47:33OS= Mac OS X 10.7.2 (11C74)
337602011/12/0413:47:33File=AdlmIntNWFBLicense.cpp
337602011/12/0413:47:33AdlmIntError=20 [License check out failed]
Thanks!
- Highlight
- Email to a Friend
sorry, had to change account. Was Ksckreate, now kscpost
- Highlight
- Email to a Friend
Hi. Thanks for posting the log files.
It looks like your problem is related to the Mac's hostname. Let's make sure your license files point to 127.0.0.1
Please type the following commands in a Terminal:
cat /usr/local/flexnetserver/adsk_server.lic | grep SERVER
cat /var/flexlm/autodesk.lic | grep SERVER
The output of each of these commands should start with SERVER 127.0.0.1
If you don't get 127.0.0.1 please let me know and I'll show you how to edit the files.
Thanks!
Robert.
- Highlight
- Email to a Friend
Here they are...
SERVER Smoke-Edit-1 e80688cd065d
USE_SERVER
USE_SERVER
Thanks.
