John Mayo wrote:
> One office with one server that will be taken' down. We don't host any
> websites or share data online. It's primary use will be a file server
> (Civil 3d 2007, Raster Design, MS Office,etc.) and license manager. It
> will be the only server. 6 cad clients, 4 office clients. We access a
> large raster image library and database often. The office is wired
> entirely CAT 5.
Your spec looks pretty good; six CAD clients + 4 office clients is a
fairly light load for that server. I'm running with about 15 CAD
clients, 5 MapInfo clients, SQL Server, MapGuide (with about 10
concurrent users, 400 total) with associated Cold Fusion reporting over
IIS, and some blackberry mobile apps on a dual-800mhz machine with 2Gb
RAM. It rarely goes over 40% cpu, disk queue is small, and other
performance indicators are good.
I'm building a 2850 with a similar configuration to yours, but with dual
CPUs. It's not a rush job though, I just need to minimize risk from
ageing hardware.
As Travis noted, gigE is a good choice, especially for viewing orthos
over the wire. I think dual gigE comes standard on the 2800; it does on
the 2850.
Extra memory is always good, but if you're not running server
applications like databases, map servers, etc, then 2Gb is probably
going to be fine.
I'm not sure if I'm misreading, but do you have a database app running
on the server? Are you running Microsoft Small Business Server with
Exchange? If so, you may also want to consider:
- 4GB RAM
- 2nd CPU
- Splitting your backplane RAID1/RAID5 or getting a second controller.
This last option would allow you to put two disks into a RAID1
configuration for OS + transaction logs, and an additional four into
RAID5 for the database, CAD and office files, and images. If you split
the backplane (at least for the DELL controller I have experience with)
you can also add an extra drive that will act as a hot spare for either
of the RAID sets, giving even higher security.
Jason
