OOPS!!
I meant REDUNDANT servers, not distributed servers. With distributed
servers the proper way to point to the servers involves an environment
variable and does not use the licpath file at all.
Jerry Milana,
Autodesk Consulting
"jerry milana (Autodesk Consulting)" wrote in message
news:4145f543$1_2@newsprd01...
> Lonnie,
> TCP ports are declared in licpath files for distributed servers and not
for
> single servers. This is true for FLEXlm 7.2 as well.
> Jerry Milana,
> Autodesk Consulting
> "lcummins" wrote in message
> news:12322480.1095097628172.JavaMail.jive@jiveforum2.autodesk.com...
> > Hi Jimmy,
> > I found a solution to the issue which may help others. We went from a
> single server license mode to redundant mode on Map 5 when we combined the
> license with 2005. The licpath.lic file on our clients only had the
servers
> and MAC addresses in the file. When I reviewed the file, I added the TCP
> port (as the 2005 clients had) and the opening speed returned to normal.
The
> old MAP 5 single server mode used FLEXlm 7.2 and didn't use a TCP port,
but
> the FLEXlm 9.2 (from 2005) does. Hopefully this will help others.
> > Lonnie Cummins
