Looks like server perfomance is fine.
We did have a dns problem, however I think I resolved it, but we still have
the very slow network writes.
Drivers are pretty much up-to-date.
I'm stumped and open to other suggestions
...rick
"jason martin" wrote in message
news:34258EB379D5382CA64319E65916CF49@in.WebX.maYIadrTaRb...
> Rick -
> Really hard problem to diagnose. I'd start by checking the performance on
> the server (stuff like ethernet bandwidth, memory usage, paging, % disk
> time, disk queue length, processor time). IMO 256MB is a little on the
> "light" side for a w2k server, but if the server isn't paging it shouldn't
> be a problem.
> It could be almost anything including, but not limited to authentication,
> dns, network bandwidth, server "capacity", ethernet drivers, user rights,
or
> server load.
> I'd try to eliminate the server hardware first. Next step would probably
be
> updating all the network card drivers. Make sure dns is working correctly
> (if you are running ad, it is very picky about dns configuration). After
> that you just about have to resort to netmon's to see what is happening at
> the "packet" level and figure out where the "delay" is occurring.
> jason martin
> frankfurt-short-bruza
> Member of the Autodesk Discussion Forum Moderator Program
> Rick Adelsohn wrote in message
> news:FB808B8D4FD8423E4990E2317C762500@in.WebX.maYIadrTaRb...
> > We have a Win 2k server (P700 256mb) on a network with about 12 machines
> > (mixed OS's win 98, NT4, 2k pro, xp), we have very slow response
writing
> > files to the server, particularly in AutoCAD.
> > The based on communications tests, I don't think its hardware related.
> > Also, I have killed netbeui
> > Could this be an Active Directory Issue? As far as I can tell, the
server
> > is running active directory, but using our router (Linksys) as a
DHCP/DNS
> > server.
> > Any direction debugging would be appreciated.
