• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Schmidt, Andrew W.
    Slow A2K with NT 4.0 and Novell 5.0
    78 Views, 2 Replies
    02-21-2000 12:39 PM
    I am experiencing a very interesting problem. We use NT 4.0 and have a
    Novell 5.0 Server, with roaming profiles. Until recently, no one really
    roamed from machine to machine, so we did not experience any problems. Now
    we have hired a few more architects and drafters and we have more people
    than we have machines so some of them use a different machine everyday. The
    roaming profile worked great to handle this, I was able to setup their
    AutoCAD options only once and they would follow the user around to whatever
    machine they were logged on. The problem I seem to be experience is as
    follows:
    Monday: UserA works on machine A, everything is fine. User A logs out and
    their profile is copied to the network.
    Tuesday: User A works on machine B, their profile (created on Machine A)
    is copied down from the network, but when they start AutoCAD it tries to go
    back to Machine A to run. I have even made sure I executed the ACAD.EXE
    right from within AutoCAD folder, it still tries to go back to machine A. I
    looked at the AutoCAD 2000 shortcut on the desktop and sometime (not all the
    time) for Target it has \\MACHINE A\c$\R2K\ACAD.EXE (where R2K is our
    default location throughout the office) Eventually AutoCAD will start,
    (after about 3-4 minutes). I have watched the NT task manager to monitor
    the performance while AutoCAD was starting up. It shows AutoCAD 2000 as not
    responding, and has the ACAD process listed, but not using any CPU.
    My only solution so far is to completely delete the User A profile from both
    the local machines and the network and recreate it each time they log onto a
    different machine. It appears to me that when User A is logged onto Machine
    B, Machine B is using the ACAD.EXE on Machine A. I am also posting with
    Novell and Microsoft this same problem in hopes of finding a solution.
    Thanks in Advance
    Andrew W. Schmidt
    CAD Manager
    Foreman Architects Engineers
    andrew.schmidt@foremangroup.com
    Please use plain text.
    *Gilmer, Tom
    Re: Slow A2K with NT 4.0 and Novell 5.0
    02-21-2000 04:29 PM in reply to: *Schmidt, Andrew W.
    <<< Message <88sb3g$rvh11@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.customization.vba' on Mon, 21 Feb 2000 16:33:15 -0500.>>>
    Frank,
    Sure do!! Below is an excerpt from the Documentation - Tom
    Location profiles allow a workstation or network administrator to save
    the information from a user's specific login into a location
    profile. When the user selects this profile when logging in, the profile
    automatically sets up login information such as the user's
    name, server, tree, context, login script, and other applicable
    information so that the user does not have to type this information.
    Location profiles are especially powerful for those users who log in
    from multiple places. Users can have separate profiles for the
    office, home, the laptop they use when they travel, and any other
    workstation they use. This simplifies the login process and makes
    it so users do not have to remember their login information for each
    workstation. Using multiple location profiles also gives the
    network administrator control over what users can access from each
    workstation.
    Frank Oquendo wrote in message
    news:88s87c$rvt9@adesknews2.autodesk.com...
    > Are you saying that Novell 5 supports roaming profiles for NT
    workstations?
    > Visit me at: http://www2.stonemedia.com/franko
    *Oquendo, Frank
    <<< Message <88s87c$rvt9@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.customization.vba' on Mon, 21 Feb 2000 14:48:57 -0600.>>>
    Are you saying that Novell 5 supports roaming profiles for NT workstations?
