Installation & Licensing
Member
Message 1 of 10 (284 Views)
Sketchbook Serial Number does not work
284 Views, 9 Replies
01-11-2013 03:44 AM
We have Autodesk Entertainment Creation Suite Ultimate 2013 however the serial number provided does not work with Sketchbook.  However it does work with the other programs in the suite.
philip.s
Message 2 of 10 (273 Views)
Re: Sketchbook Serial Number does not work
01-11-2013 06:00 PM in reply to: suppliercontact
Hello suppliercontact!
What OS are you installing Sketchbook Designer on? What Product Key are you using?
Philip Schmelzer
Member
Message 3 of 10 (245 Views)
01-14-2013 01:37 AM in reply to: suppliercontact
Installked on Windows 7 x64 using product key 793E1.
It is network licensed along with other products in the Entertainment Suite, the others work normally it is just Sketchbook that is not working.
Product Support
emily.xu
Message 4 of 10 (225 Views)
01-14-2013 07:19 PM in reply to: suppliercontact
Can you provide the error image or message?
Emily Xu
Member
Message 5 of 10 (220 Views)
01-15-2013 01:59 AM in reply to: suppliercontact
No error message is shown, the software just does not pick up a license from the network.  Alternatively if I enter the serial number and product key in manually the button does not become available, it remanins greyed out.
Product Support
emily.xu
Message 6 of 10 (202 Views)
01-16-2013 01:24 AM in reply to: suppliercontact
I'm little bit confused about your issue.Did it happen when installation or startup? Can you capture the screen of the problem?
Emily Xu
Member
Message 7 of 10 (195 Views)
01-16-2013 05:40 AM in reply to: suppliercontact
I created a installation which installs fine, then when I launch Sketchbook it prompts for a serial number and product code.
Sorry not got screenshot yet.
philip.s
Message 8 of 10 (190 Views)
01-16-2013 01:49 PM in reply to: suppliercontact
Did you install SketchBook Designer from the suite package (required on a PC) or as a separate component?
Philip Schmelzer
Member
Message 9 of 10 (182 Views)
01-17-2013 01:31 AM in reply to: suppliercontact
I installed it as part of the suite.
Product Support
emily.xu
Message 10 of 10 (157 Views)
01-24-2013 11:22 PM in reply to: suppliercontact
If you installed the sketchbook as a part of suite and network license, it will try to get the license when you start it. Only the product installed with standalone license mode, maybe require the SN and PK. So, can you try to reinstall your sketchbook with the suite media and make sure install with network license mode?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
