• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Sketchbook Serial Number does not work
    217 Views, 9 Replies
    01-11-2013 03:44 AM
    We have Autodesk Entertainment Creation Suite Ultimate 2013 however the serial number provided does not work with Sketchbook.  However it does work with the other programs in the suite.
    Please use plain text.
    philip.s
    Re: Sketchbook Serial Number does not work
    01-11-2013 06:00 PM in reply to: suppliercontact
    Hello suppliercontact!
    What OS are you installing Sketchbook Designer on? What Product Key are you using?
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    01-14-2013 01:37 AM in reply to: suppliercontact
    Installked on Windows 7 x64 using product key 793E1.
    It is network licensed along with other products in the Entertainment Suite, the others work normally it is just Sketchbook that is not working.
    Product Support
    emily.xu
    01-14-2013 07:19 PM in reply to: suppliercontact
    Can you provide the error image or message?
    Emily Xu
    AutodeskCare | Product Support
    Member
    01-15-2013 01:59 AM in reply to: suppliercontact
    No error message is shown, the software just does not pick up a license from the network.  Alternatively if I enter the serial number and product key in manually the button does not become available, it remanins greyed out.
    Product Support
    emily.xu
    01-16-2013 01:24 AM in reply to: suppliercontact
    I'm little bit confused about your issue.Did it happen when installation or startup? Can you capture the screen of the problem?
    Emily Xu
    Member
    01-16-2013 05:40 AM in reply to: suppliercontact
    I created a installation which installs fine, then when I launch Sketchbook it prompts for a serial number and product code.
    Sorry not got screenshot yet.
    philip.s
    01-16-2013 01:49 PM in reply to: suppliercontact
    Did you install SketchBook Designer from the suite package (required on a PC) or as a separate component?
    Philip Schmelzer
    TW | PI | YT | BLOG
    Member
    01-17-2013 01:31 AM in reply to: suppliercontact
    I installed it as part of the suite.
    Product Support
    emily.xu
    01-24-2013 11:22 PM in reply to: suppliercontact
    If you installed the sketchbook as a part of suite and network license, it will try to get the license when you start it. Only the product installed with standalone license mode, maybe require the SN and PK. So, can you try to reinstall your sketchbook with the suite media and make sure install with network license mode?
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Emily Xu
