Installation & Licensing
Member
p002573a
Message 1 of 10 (673 Views)
Sketchbook Pro Product Activation
673 Views, 9 Replies
06-24-2013 03:30 PM
Hi there!
Had sketchbook pro installed for a while now.  Just put it on my new hard drive and have been promted to enter my serial number and product key, no problem as they're both listed in my software.  However doing these (copy+pasting or manually typing) leaves me with a greyed out "ok" box.  I'm stuck either with a 15 day trial or not using it.
I have included a screenshot of the window to clarify and look forward to a response.
Thanks, John
Customer Service
amanda.k
Message 2 of 10 (665 Views)
Re: Sketchbook Pro Product Activation
06-24-2013 04:06 PM in reply to: p002573a
Hello John,
Welcome to the Forums!
Most likely this is due to needing to update your product with a Service Pack. Please visit the Sketchbook Pro Service Packs and select the appropriate update for your license, then attempt to activate again. Let us know how it goes!
Amanda Kinley
Member
p002573a
Message 3 of 10 (662 Views)
06-24-2013 04:20 PM in reply to: amanda.k
Hi Amanda,
Thanks for the quick reply.  I updated to service pack 4, which is listed as the most recent for windows, however it doesn't seem to have solved the problem.  I'm left with the same issue as in my original post.
Cheers, John
Member
p002573a
Message 4 of 10 (629 Views)
06-26-2013 05:58 AM in reply to: p002573a
Just bumping this thread in the hope that I get another response.  After the first failed attempt at solving the issue, I've heard nothing back.
Member
p002573a
Message 5 of 10 (585 Views)
06-30-2013 10:38 AM in reply to: amanda.k
Still waiting to hear back about the sketchbook pro activation issues.  I tried the solution you suggested nearly a week ago and have heard nothing back.
Could a customer service representative please contact me?
Customer Service
joane.bonghanoy
Message 6 of 10 (576 Views)
06-30-2013 07:06 PM in reply to: p002573a
Hi p002573a,
My apologies for the trouble this caused you.
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code
Joane Bonghanoy
New Member
xavi.pato
Message 7 of 10 (390 Views)
10-09-2013 01:30 PM in reply to: joane.bonghanoy
hi i have the same problem, could you help me please!!!
philip.s
Message 8 of 10 (379 Views)
10-09-2013 02:44 PM in reply to: xavi.pato
Hello Xavier,
Can you also please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code or contact or License Assistance Team for direct support?
Philip Schmelzer
Ren.Torres
Message 9 of 10 (364 Views)
10-14-2013 10:09 AM in reply to: xavi.pato
Hello Xavier!
If you license is for the Autodesk Sketchbook Pro 6, this does not require any activation.  You can just plug in your serial number (xxx-xxxxxxxx), together with the product key 732E1 (upper case for the alpha character), and you should be able to use the full version afterwards.
Let me know if this helps.
Renamel Torres
Ren.Torres
Message 10 of 10 (362 Views)
10-14-2013 10:11 AM in reply to: p002573a
Hello John!
If your license is for the Autodesk Sketchbook Pro 2011, this does not require any activation.  Please try pluging in your serial number again (xxx-xxxxxxxx), together with the product key 732C1 (upper case for the alpha charater "C").  You should be able to use the full term of your sudent license then.
Let me know if this works.
Renamel Torres
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
