installed Autodesk Map2005(Single version).
I Used after Autodesk Map2005(Network version).
I Used by Autodesk Map2005(Network version) modifying Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R16.1\ACAD-302:412\AdLM by 19, but because 'timeout' option function is not operated.
Is part that must be modified separately to use 'timeout' option function?
