Is there any way to make a single installer for the entire Education Master Suite. Currently I have to create deployment installers for each package in the suite. A deployment that includes all of the packages (or be able to select which packages go into the deployment installer) would be very handy but I do not see that as a current option.
Pruittj,
You cannot create one deployment with all of the applications within the Autodesk Education Master Suite. However, if you had one of the following suites (which is also available to Education customers) you would be able to accomplished this...
The suites above can create one deployment that includes all of it's applications.
Hope this helps.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
