Installation & Licensing
Simulation Composite Design Download
3 REPLIES 3
carl_vr_stud
325 Views, 3 Replies
Good Day Forums I am currently trying to download Simulation Composite Design via the student community, but when I select 64 bit the file that downloads is a 32 bit install file. This is the same as off of the Autodesk main site. Is this software only available in 32bit? Or is this an error on the download link pointing to the incorrect file? Kind Regards Carl van Rooyen
3 REPLIES 3
camilo.lemos
in reply to: carl_vr_stud
Hi carl_vr_stud, welcome to the Autodesk Community!
I've tested this and I was able to reproduce this behavior. I'll clarify with the product team and will get back to you as soon as I have an answer.
Thanks for bringing this up!
Camilo Lemos
carl_vr_stud
in reply to: camilo.lemos
Thanks for the quick response and having a look at this.
Kind Regards
Carl van Rooyen
camilo.lemos
I've just spoken to the Simulation produc team about this:
The installer will work on both the 32 and 64-bit versions, it was simply named incorrectly. You can go ahead and install this on your 64-bit system and you should run into any issues.
The product team are looking into renaming the file.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Camilo Lemos
Administrator Productivity
