Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Simulation CFD Network License error [-96.491.0 ]
- Highlight
- Email to a Friend
We recently acquired, and installed, Simulation Mechanical 2013 and Simulation CFD 2013 as networked licenses. While successfully able to have Simulation Mechanical acquire a network license, we have been unable to get CFD to acquire its license (error [-96.491.0]). We’ve tried the following license scenario’s:
- Single Simulation Mechanical license loaded by lmtools – successful.
- Single CFD license loaded by lmtools – failed (error [-96-491.0]).
- Appended/Multiple license for Simulation Mechanical and CFD loaded by lmtools – Mechanical successful, CFD failed (error [-96-491.0]).
In all the above cases, lmtools (server status and debug files) have shown the licenses successfully loaded/running and available on the server. Host name and host id (MAC) of all the license files appear correct (i.e. the same). Communication through port 2080 appears good (http://computername:2080). We have tried the following suggestions, as noted on the forum, with no success:
- Firewall ports 2080 and 27000-27009 open on all machines.
- CascadeInfo.cas renamed.
- Timeout variable increased.
Any suggestions are assistance would be greatly appreciated. Thanks in advance!
Re: Simulation CFD Network License error [-96.491.0 ]
- Highlight
- Email to a Friend
Post your server status enquiry and debug log files.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
- Highlight
- Email to a Friend
Solution found. We had not registered and recieved the second serial numbers license file. As we received two disc packs with the same SKU (diferent serial numbers) and, when we tried to install the second pack/disk we received an already installed notice, we believed we had a duplicate shipped to us in error. However, after getting the serial number and license files for both, appending them together, we are now up and running. Our bad.
- Highlight
- Email to a Friend
Excellent. That was what I wanted to verify in your logs. Glad you got it up and running.
