Hi, what is the command to silently (or preferably passively) install inventor viewer 2012?
I tried using the msi file included, and it just put a note in the event viewer saying I must run it from setup.exe.
I don't need to customize anything, just want to install on several computers without running through the setup everytime.
Solved by emily.xu. Go to Solution.
You can try this solution: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13863010&linkID=9242018. Though it is for 2011 and previous version, but I think it will apply for 2012 version.
Close, but not quite.
When my install script gets to inventor viewer it asks for permission to run the msi's.
When I use the below command for any other msi it installs passively without permission. I'm looking for a simular unattended setup.
msiexec /i "FolderSize-2.4.msi" /passive /norestart
I've now also gotten the below error when installing using this command line on 2 out of 3 of the computers I went to install using this method. Yet it installs just fine if I manually run the exe. All of my computers in question are fully updated using MS's WSUS server and on XP SP3.
This installation package cannot be installed by the windows installer service. You must install a Windows service pack that contains a newer version of the Windows Installer service.
The machines need .NET framework 3.5 SP1 installed before you can run these commands. You can find the prerequisite in Setup.ini file.
I looked at my WSUS and it says .Net 3.5 SP1 is "installed or NA" for all computers. No errors.
In addition attached you will find an example where .net 3.5 SP1 is installed, but I get the afore mentioned error. I've also followed up with an additional example.
From the error image, there maybe somthing wrong with the Windows installer, I would suggest you try to re-register (re-install) the Microsoft Windows Installer by this solution: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10304950&linkID=9240617.
If above not solve your problem, then try to install the latest version of the Microsoft Windows Installer from the Microsoft website.
Doing what your hyperlink says to do works. Thanks.
I tried just setting the script to passively re-install, using the below command, before trying to install Inventor Viewer, but that doesn't seem to be enough. Guess when I get this error I'll just have to manually install. 😞
"Inventor Viewer 2012 x86\Msi\WindowsInstaller-KB893803-v2-x86.exe" /passive
Any update on silently installing without requiring me to click run?
Also, I'm starting to notice there is a lot of overlap between my 5 different AutoCAD viewer install folders. Is there someway for me to reduce the space this stuff takes up by combining (or deleting) the repeated folders? If so, is it documented somewhere what folders are repeated, and perhaps a suggested method? Or perhaps a single download that combines the 32 and 64 bit versions?
The different readers I use are (all 2012):
Design Review
TrueView x86
TrueView x64
Inventor View x86
Inventor View x64
So the entire script that installs inventor viewer "nearly silently" goes like this:
REM If there is an error installing Inventor Viewer you will need to manually install it. Or
REM msiexec /unregister
REM del %systemroot%\system32\msi.dll
REM del %systemroot%\system32\msiexec.exe
REM del %systemroot%\system32\msihnd.dll
REM RebootREM "CAD\Inventor Viewer 2012 x86\Msi\WindowsInstaller-KB893803-v2-x86.exe" /passive
if /i %Processor_Architecture%==AMD64 goto 64bit
goto 32bit
:32bit
ECHO Installing Inventor Viewer
"Inventor Viewer 2012 x86\x86\InventorView\InventorView.msi" ADSK_SETUP_EXE=1 /qb
ECHO Installing Inventor Viewer English Launguage Pack
"Inventor Viewer 2012 x86\x86\en-US\InventorView\InventorViewLP.msi" ADSK_SETUP_EXE=1 /qb
goto 3264bit
:64bit
"CAD\Inventor Viewer 2012 x64\x64\InventorView\InventorView.msi" ADSK_SETUP_EXE=1 /qb
"CAD\Inventor Viewer 2012 x64\x64\en-US\InventorView\InventorViewLP.msi" ADSK_SETUP_EXE=1 /qb
goto 3264bit
:3264bit
REM No shared software to install here
Echo Done instaling Inventor Viewer 2012
