As an IT Officer in a school we have recently decided we will need to upgrade our inventor version to 2011.
As there are several labs to do this on I would ideally like to do this silently.
I can happily deploy it silently but is there a way to uninstall silently??
Warwick
You can use the tool mentioned here; it should work for 2010 too.
http://usa.autodesk.com/getdoc/id=TS14893355
I already found the uninstall tool.
Is there a command line option with this product?
If so do you know what they are?? I cannot find any documentation which says what the command line options are.
Regards
Warwick
To uninstall inventor 2010 32bit, run the commands in sequence:
msiexec /x {52969324-463B-4643-BF36-854BE2BECB89} /q
To uninstall inventor 2010 64bit, run the commands in sequence:
