Installation & Licensing
Member
esutter
Message 1 of 5 (732 Views)
Showcase 2014 fails to open
732 Views, 4 Replies
06-10-2013 03:28 PM
XPost from the Showcase forums, but I see it doesn't get as much traffic as this does:
I just installed Showcase 64 bit on to Win 7 - 64 Pro and I see the following:
Error Report - Required Value Missing
An Autodesk product failed to send the required value for SERIALNUM
The error report sent to Autodesk may be incomplete.
And the software won't install. I input the Serial Number and it was accepted during installation.
philip.s
Message 2 of 5 (724 Views)
Re: Showcase 2014 fails to open
06-10-2013 04:48 PM in reply to: esutter
HI Eric,
Can you please check the Windows Features and make sure that .net framework is enabled. If so what version is installed?
Start button -> Control Panel -> Programs -> Turn Windows features on or off
Philip Schmelzer
Member
esutter
Message 3 of 5 (721 Views)
06-10-2013 05:32 PM in reply to: philip.s
I'm a .NET developer, I have all versions of .NET installed
Product Support
david.lau
Message 4 of 5 (694 Views)
06-12-2013 12:42 PM in reply to: esutter
Member
esutter
Message 5 of 5 (686 Views)
06-12-2013 12:49 PM in reply to: david.lau
Yes, David Lau's solution worked. Thank you.
(hmm, someone accepted this as solution before I verified it... oh well)
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
