I have registered and been approved as an educational institute for installing the Autocad 2014 suite. I've read that the installers for this are the network version only. I've been emailed a SN and also submitted my license server details and had a license file returned via email to me.
I've set my license server up as per your instructions with the license file.
However, none of the applications will run. They all give me a invalid Serial Number error and at no point am I prompted for the license server details from the clients.
Please help.
Ivan
its probably because your installing as a standalone and not as network
if you are installing as network it does ask for server name
DarrenP
Thanks for the reply Darren. I was beginning to suspect that. I take it that is also why my SN is being rejected?
Why then is that the only set of downloads I can access? There are no standalone or network versions to choose from. Just the name of the application and 32 or 64-bit.
Seeing as I have now installed this on 26 PCs what are my options to getting AutoCAD and 3DS Max 2014 activated?
Ivan
the standalone and network version are bundled in the same install/download
when installing you choose the correct version
DarrenP
Ivan
you may have to uninstall/reinstall if you installed them as a standalone
DarrenP
I'll try uninstalling and re-installing it again. I don't remember seeing that as an option whilst installing.
Thanks Darren, I uninstalled and reinstalled AutoCAD2014 and selected network license and that's all working now.
We are however also wanting to use 3DSMax and the S/N is different to the AutoCAD 2014 one.
As far as I can see the license server can only use the one license file so how do I enable it for both applications?
I get 'A valid license could not be obtained by the network license manager' error.
thanks.
DarrenP
Brilliant! That's just what I was looking for (if I knew what I was looking for) - all sorted now
Thanks Darren you're a star!
