• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Doherty, Tim
    Service Pack 2
    78 Views, 2 Replies
    01-15-2001 09:12 PM
    I am looking at installing Service Pack 2 to our network version of AutoCAD
    2000i. Since this is a network version, do I install the Service Pack on
    the server or do I install it at the individual workstations?
    Please use plain text.
    *milana, jerry
    Re: Service Pack 2
    01-16-2001 07:45 AM in reply to: *Doherty, Tim
    Tim,
    If you have the AutoCAD runtree on each workstation, then the SP should be
    installed on each workstation. Also note that for 2000i, the "unlocked" SP
    is used for network versions, not the 'locked' SP as with previous AutoCAD
    releases.
    jerry milana,
    Autodesk Product Support
    "Tim Doherty" wrote in message
    news:E554C683E38AEDCF2F586D4C2564F998@in.WebX.SaUCah8kaAW...
    AutoCAD
    *Schroeder, Bud
    Re: Service Pack 2
    01-16-2001 03:47 PM in reply to: *Doherty, Tim
    Hi Tim,
    To add to what Jerry told you. If your running the Network install (ACAD.EXE
    on the server) you want to patch the admin system first. This is the system
    that created the deployment and then installed AutoCAD to the server location.
    Be sure to close down all running AutoCADs before you patch them.
    Hope this helps.
    Bud
