Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Service Outside Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have 212 NLM licenses of autodesk Products.
The service is running ok inside the LAN, and through the WAN via VPN, no problems in there.
But we want to publish the server to the web, because we have users sccatered through more than 30 cities.
We published the server with DMZ, opened the Ports 2080 and 27000 through 27010.
we can ping the server from the client machine, but the software is not running. it sends an error: "Failed to obtain the IP Adress of the machine SERVERNAME"
we will control the users through a OPT File that it is working fine.
Re: Service Outside Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Technically, opening up your NLM to the Internet is not only dangerous, but it violates the license agreement. In any case, your issue is likely one that can be solved with a hosts file entry and a FLEXLM_TIMEOUT system environment variable.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
