Installation & Licensing
Service Created by Autocad 2011 NLM Doesn't Start in Server 2003
11 REPLIES 11
Message 1 of 12
ErnestMaicle
6451 Views, 11 Replies
with the ff. error:
adskflex: The desired vendor daemon is down.
 Check the lmgrd log file, or try lmreread.
Vendor:Host:   <server name>
License path:  27000@<server name>
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
11 REPLIES 11
Message 2 of 12
Please check the log file there must be more error, refering to the license file,system name etc..
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Message 3 of 12
I finally got the Service running but I got the following errors on my log file:
12:39:36 (lmgrd) World Wide Web:  http://www.acresso.com
12:39:36 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\Hofschneider Eng All 2010.lic
12:39:36 (lmgrd) lmgrd tcp-port 27000
12:39:36 (lmgrd) Starting vendor daemons ...
12:39:36 (lmgrd) Starting vendor daemon at port 2080
12:39:36 (lmgrd) Using vendor daemon port 2080 specified in license file
12:39:36 (lmgrd) Started adskflex (pid 3740)
12:39:37 (adskflex) Unable to initialize access to trusted storage: 1
12:39:37 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
12:39:37 (adskflex) Server started on server.hofschneider.com for:
12:39:37 (adskflex) 64300ACD_F (consisting of:        85536ACD_2011_0F
12:39:37 (adskflex) 71200ACD_2010_0F 57600ACD_2009_0F 54600ACD_2008_0F)
12:39:37 (adskflex) 64900CIV3D_F (consisting of:        85604CIV3D_2011_0F
12:39:37 (adskflex) 73700CIV3D_2010_0F 59700CIV3D_2009_0F 55400CIV3D_2008_0F)
12:39:37 (adskflex) PLIST        PLIST
12:39:37 (adskflex) Wrong hostid on SERVER line for license file:
12:39:37 (adskflex)     C:\Program Files\Autodesk Network License Manager\Hofschneider Eng All 2010.lic
12:39:37 (adskflex) SERVER line says 033048b9ea21, hostid is "003048b9ea21 003048b9ea20"
12:39:37 (adskflex) Invalid hostid on SERVER line
12:39:37 (adskflex) Disabling 3 licenses from feature 54600ACD_2008_0F(12ED 3A4E 6073 47BD )
12:39:37 (adskflex) Disabling 1 license from feature 55400CIV3D_2008_0F(1B1C 5792 4355 1366 )
12:39:37 (adskflex) Disabling 3 licenses from feature 57600ACD_2009_0F(12ED 3A4E 6073 47BD )
12:39:37 (adskflex) Disabling 1 license from feature 59700CIV3D_2009_0F(1B1C 5792 4355 1366 )
12:39:37 (adskflex) Disabling 3 licenses from feature 64300ACD_F(12ED 3A4E 6073 47BD )
12:39:37 (adskflex) Disabling 1 license from feature 64900CIV3D_F(1B1C 5792 4355 1366 )
12:39:37 (adskflex) Disabling 3 licenses from feature 71200ACD_2010_0F(12ED 3A4E 6073 47BD )
12:39:37 (adskflex) Disabling 1 license from feature 73700CIV3D_2010_0F(1B1C 5792 4355 1366 )
12:39:37 (adskflex) Disabling 3 licenses from feature 85536ACD_2011_0F(12ED 3A4E 6073 47BD )
12:39:37 (adskflex) Disabling 1 license from feature 85604CIV3D_2011_0F(1B1C 5792 4355 1366 )
12:39:37 (adskflex) Disabling 1 license from feature PLIST(0D32 031D 42E3 F079 )
12:39:37 (adskflex) Disabling 1 license from feature PLIST(0D90 C204 D42B 26D3 )
12:39:37 (adskflex) EXTERNAL FILTERS are OFF
12:39:37 (lmgrd) adskflex using TCP-port 2080
12:39:37 (adskflex) No valid hostids, exiting
12:39:37 (adskflex) EXITING DUE TO SIGNAL 25 Exit reason 2
12:39:37 (lmgrd) adskflex exited with status 25 (Invalid host)
12:39:37 (lmgrd) Please correct problem and restart daemons
Message 4 of 12
is this a teamed network interface. system seem to report wrong mac address ?
doest ipconfig /all report the mac address right ?
Hashim Mundol
Message 5 of 12
What do you mean teamed network interface?
I have my license file for Autodesk regular and Autodesk 3D in one license file. I actually had it working for a long time using version 2010 for both. Now I was tasked to upgrade it to our 2011 version, and so what I did was to uninstall the NLM 2010 and installed NLM 2011. I acquired a license file and did the same procedure when I did 2010. Unfortunately, I didn't have it working. I got frustrated and uninstalled 2011 and put back 2010 but to same result. Now even my 2010 is not working.
By the way, I am using Server 2003.
Message 6 of 12
If possible try to disable the network interface with the Mac ID :003048b9ea20
Hashim Mundol
Message 7 of 12
ErnestMaicle
in reply to: ErnestMaicle
I already was able to resolve the Services on my MS 2003 server. But I still have problems with my NLM. I am getting errors on my log file. and I am getting a lot of these invalid license key error(s). Should I acquire a new license file? Please help.
LOG FILE ERRORS:
14:26:54 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 i86_n3) started on server.hofschneider.com (IBM PC) (9/18/2010)
14:26:54 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
14:26:54 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:26:54 (lmgrd) World Wide Web:  http://www.acresso.com
14:26:54 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\hofschneider.lic
14:26:54 (lmgrd) lmgrd tcp-port 27000
14:26:54 (lmgrd) Starting vendor daemons ...
14:26:54 (lmgrd) Starting vendor daemon at port 2080
14:26:54 (lmgrd) Using vendor daemon port 2080 specified in license file
14:26:54 (lmgrd) Started adskflex (pid 1792)
14:26:54 (adskflex) Unable to initialize access to trusted storage: 1
14:26:54 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79956 i86_n3
14:26:54 (adskflex) Invalid license key (inconsistent authentication code)
14:26:54 (adskflex)     ==>INCREMENT 64300ACD_F adskflex 3.000 permanent 3 \
    VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=UH \
    SUITE_DUP_GROUP=UHV ISSUED=08-Sep-2010 BORROW=4320 \........................
Message 8 of 12
if you havent made any changes to the license file received from autodesk and if the mac address is the same it should work.
if you modified any of those, its best to get a new file.
Hashim Mundol
Message 9 of 12
poltorakja
in reply to: hashim.mundol
How do you request a new .lic.  We had a NIC go bad and swapped it out so the MAC Address did change.  We are using Autocad 2011
Message 10 of 12
DarrenP
in reply to: poltorakja
To Obtain a license file:
Contact the Autodesk Registration and Authorization office and provide the following information: 1-800-551-1490 or authcodes@autodesk.com you need:
  • Product serial number(s)
  • Server name
  • Host ID (Ethernet Address)
  • An email address where Autodesk can send the license file.
to set up the license manager: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14379546&linkID=9240617
DarrenP
Message 11 of 12
grosales
I'm having the same issue.
Are you saying that the .lic file needs to be created from the host server because it takes the NIC MAC address from the native system the license file was created from into account?
Message 12 of 12
DarrenP
in reply to: grosales
the license file needs to be tied to the server that will be running LM tools
DarrenP
Administrator Productivity
