Installation & Licensing
septagon
Message 1 of 3 (84 Views)
Server swap, network licenses...
84 Views, 2 Replies
02-20-2001 06:42 AM
IT is currently swapping our servers. They are under the impression that they must reinstall the stations which pull licenses from the old server so that they will be able to obtain licenses from the new server. Is it not possible to "redefine" the licensing path on the workstation to find the correct (new) server? If so, some details would be spiffy...
*martin, jason
Message 2 of 3 (84 Views)
Re: Server swap, network licenses...
02-20-2001 07:00 AM in reply to: septagon
Assuming that you are doing client deployments (meaning that the acad.exe, and other
associated files are located on the clients, and not on the server) and assuming that the
new server is in the same subnet as the old server it shouldn't really be any big deal.
If there is an acadserver variable defined on the workstations just change it to the new
name of the server (host name, not netbios name).
If there isn't an acadserver variable defined the adlm and licensing should just
automaigically work.
Have them build the new server, install adlm, get the new auth codes (you will need new
auth codes from autodesk, call the 800 number in the installation guide), shut down the
old aldm server (don't re-format, wipe, change ip's or anything else increadibly stupid,
just shut it down) make sure that the new adlm server's adlm service is started (you have
to do this manually) and try launching autocad from one of the clients. If it doesn't
work check the acadserver variable. If it's set to something, change it to the new server
and try again. If all else fails you can still bring the old server back up until you
figure out what the problem is.
hth
jason martin
frankfurt-short-bruza
"septagon" wrote in message news:f02beaf.-1@WebX.maYIadrTaRb...
spiffy...
*martin, jason
Message 3 of 3 (84 Views)
Re:
02-20-2001 09:38 AM in reply to: septagon
Just as a clarification to my previous post...
Even if you are using a network heavy deployment (meaning acad.exe is
installed on the server) it is still possible to move everything to another
server. If the network install is on a server that is also being replaced
it is a bit more tricky, but it is still possible. Our R14 deployment was a
network heavy install to a netware server, and our adlm was running on a NT
machine. Both have been replaced with absolutely no change in the clients
whatsoever (I don't use an acadserver variable).
If the acadserver variable is being used with an @servername then it must be
changed. If you just have servername as the acadserver variable the client
will figure out that servername isn't responding and will "broadcast" to all
of the machines in the subnet to see if anyone will respond as being an adlm
server.
hth
jason martin
jason martin wrote in message
news:C7F81A12131929512377309EFF058B6B@in.WebX.maYIadrTaRb...
and other
assuming that the
any big deal.
it to the new
should just
will need new
shut down the
increadibly stupid,
started (you have
If it doesn't
to the new server
up until you
> hth
> jason martin
they must
they will be able
the licensing
details would be
> spiffy...
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
