Looking to spec a server to run Autocad for our school. Will run twenty work stations using Intuos Pro Pen & Touch Tablets and output to laser cutter and 3D printer. Possible addition of CNC Milling machine and CNC router in the future.
you don't actually run Autocad on a server
DarrenP
Hello. You need to install on a supported operating system. These are the tested systems. There are no explicitly supported server environments for the installation of the program. I know Windows Server environs are often just like Win 7 or Win 8, however, they are untested. I would give the install a try first.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15412189&linkID=9240617
Thank you for taking part in our community!
