Installation & Licensing
Server name in License File
8 REPLIES 8
Message 1 of 9
andrew.warren
964 Views, 8 Replies
I am getting an error when I try to run reports on our license file. Acording to this http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13587543&linkID=12544120 you need the file and Ethernet Address to match. In my file we have the  server name and then the first MAC Address. Should they both be in thier or is somehting else causing the error?
Andy Warren
BCDesign@bellsouth.net
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: andrew.warren
you should only have 1 mac address in the license file
DarrenP
Message 3 of 9
DarrenP
in reply to: DarrenP
what does lm tools say the MAC Address is?
DarrenP
Message 4 of 9
andrew.warren
"00188b53ce28 00188b53ce2a" License file calls out  00188b53ce28
Andy Warren
Message 5 of 9
DarrenP
what about the servername?
did that change or get misspelled in the license file?
DarrenP
Message 6 of 9
andrew.warren
No it appears to be OK...
Here is what I get when I try to run the SAM report...
Warning: Unable to read report log D:\Program Files\Macrovision\samreport\2012log.rl:No license found for ADSKFLEX/00188b53ce28.
The desired vendor daemon is down.
 Check the lmgrd log file, or try lmreread.
Feature:       Common.FLEXnet.Report
Vendor:Host:   cad1-na-asc.bfusa.com
License path:  D:\Program Files\Macrovision\samreport\v3.6\machind\license -
   \license.dat;C:\Program Files\Common Files\Rockwell\Activations\*.lic;
   C:\Documents and Settings\All Users\Documents\Rockwell Automation -
   \Activations\ftasystem.lic;C:\Documents and Settings\All Users\Documents -
   \Rockwell Automation\Activations\HOST00188B53CE28_NodeLocked_201201100328023 -
   87.lic;C:\Documents and Settings\All Users\Application Data\Rockwell -
    Automation\Dongle;START_LICENSE INCREMENT SAMreport_vendor gsi 3.0 -
    permanent uncounted BB9F528109E4 VENDOR_STRING="VENDOR:gsi HOSTID -
   :8093dede" HOSTID=ANY NOTICE="For use only with sample.rl"
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com". Continuing...
Unable to generate report: Error: No report logs to process
description is <VENDOR_STRING="VENDOR:adskflex HOSTID:00188b53ce28">
Andy Warren
Message 7 of 9
DarrenP
i'm not to familar with sam report
someone else is going to have to step in and answer
DarrenP
Message 8 of 9
TravisNave
SAMreport does not use LMTOOLS to license itself.  That is done within the SAMreport program itself.  You need to make sure that the license .dat file you obtained is placed in the correct location after install.  For example, mine is here:
C:\Program Files (x86)\Macrovision\samreport\v3.6\machind\license\license.dat
When you launch SAMreport, you should note in the title bar that it is properly registered to you.
LMTOOLS only creates the report.rl log which is used by SAMreport to read in the license usage.
If this is your first time setting up and using SAMreport Lite, please start here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2538394&linkID=9240618
Note than this product has been deprecated and is no longer supported.  Jimmy has a newer alternate called JTB FlexReport that might interest you.  You might check it out.
http://forums.autodesk.com/t5/Classifieds/JTB-FlexReport-1-0-released-as-freeware-FlexNet-HTML-repor...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 9 of 9
andrew.warren
in reply to: TravisNave
It has been awhile since I last used it and even then it wasn't much more than playing with it to learn licensing as a AE. The license file is in the correct place but it seems SAM doesn't like it. I have a trial from JT and am going to play wiht it over the next week or two.
Andy Warren
Administrator Productivity
