Installation & Licensing
338 Views, 4 Replies
Server code
1- If I change the server name, the server code from Adlm 2000i will change to?
2- And if i upgrade my operating system to Windows server 2000, the server code from the adlm 2000i will change to?
thanks in advance
4 REPLIES 4
Either change you mention MAY cause a server code
change and you should plan for that possibility.  The algorithm used to
determine which parameters are used to generate the server code is complex and
thus there is no way to know for sure if changing a given parameter will cause a
server code change.
Jerry Milana,
Autodesk Professional
Services
1-
thanks in advance
ya but the license file only has machine name and mac address as variables?
"jerry milana"
|>server code change.
Jerry Milana,
|>Services
|> 1-
thanks in advance
True for AutoCAD 2002 and 2004 but not for earlier versions.
Jerry Milana,
Autodesk Professional Services
"Dave Lewis" wrote in message
news:njqlbvgniktni59mhbdof5nv7bf9pqm06k@4ax.com...
variables?
> "jerry milana"
server code
used to
complex and
cause a
> |>server code change.
Jerry Milana,
Professional
> |>Services
> |> 1-
change to?
server
thanks in advance
whats required for earlier versions?
"jerry milana"
Administrator Productivity
