Serious problem with MAX Des 2010 and/or MAX Des 2011 and Win7 64bit
I had MAXDes2010 installed and I tried to install MAXDes2011... But I had a problem with my installation and had to repeat...
Now, Ican't install any of them... The setup program tries to install .Net3.5 which was already installed but it fails, then it installs DirectX updates and then it can't continue... I also installed .net 4.0 which I found from Microsoft site thinking that there was an error with my .net framework installation...
What I think is best to do now, is to eliminate any leftovers from the registry and the disks and start again... I tried this using regedit, advanced uninstaller, ccleaner etc... nothing...
Is there any small app from autodesk or any tips that can help? It would be really difficult for me to format and re-setup my PC...
Thank you in advance for any help, please take a look at the attached files.
This is the setup.log
2010/4/22:20:09:58 JTB PC11 === Setup started on PC11 by JTB ===
2010/4/22:20:10:46 JTB PC11 === Setup ended ===
2010/4/22:20:10:19 JTB PC11 === Setup started on PC11 by JTB ===
2010/4/22:20:13:41 JTB PC11 Install .NET Framework Runtime 3.5 SP1 (This may take several minutes) Failed Failure is ignored, Result=1603
2010/4/22:20:14:19 JTB PC11 Install DirectX® Runtime Update Succeeded
2010/4/22:20:15:22 JTB PC11 === Setup ended ===
2010/4/23:09:18:27 JTB PC11 === Setup started on PC11 by JTB ===
2010/4/23:09:19:15 JTB PC11 === Setup ended ===
2010/4/23:09:40:13 JTB PC11 === Setup started on PC11 by JTB ===
2010/4/23:09:41:01 JTB PC11 === Setup ended ===
2010/4/23:09:40:34 JTB PC11 === Setup started on PC11 by JTB ===
2010/4/23:09:57:40 JTB PC11 Install .NET Framework Runtime 3.5 SP1 (This may take several minutes) Failed Failure is ignored, Result=1603
2010/4/23:09:58:17 JTB PC11 Install DirectX® Runtime Update Succeeded
2010/4/23:09:58:18 JTB PC11 Install Autodesk 3ds Max Design 2011 64-bit Failed Installation aborted, Result=1610
2010/4/23:09:58:18 JTB PC11 Rollback DirectX® Runtime Update Failed Failure is ignored, Result=1619
