Installation & Licensing
Serious Error - Library .... d3dx9_42.dll does not exist
6 REPLIES 6
2259 Views, 6 Replies
Just installed Inventor PDS 2012 and when trying to open a file or start a new file in Inventor - I get "Serious Error - Library c:\program files\autodesk\inventor 2012\bin\d3dx9_42.dll does not exist"  -  Then Inventor crashes.
I found the d3dx9_42.dll file on the USB stick and copied it in the file listed above, rebooted - and still same problem.
Any suggestions much appreciated
Jim
6 REPLIES 6
hashim.mundol
Please install directx from the MS site or from the media
http://www.microsoft.com/download/en/details.aspx?id=35
http://www.microsoft.com/download/en/details.aspx?id=8109
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
in reply to: hashim.mundol
I did the DirectX downloads, rebooted, and still same problem.
Didnt work.
Dazzman
Check c:\windows\system32 and put it in there.
Hope it helps.
Thanks Dazzman - That folder had the file in it, but it was a different size than the file supplied by Autodesk, so I copied the file from my new Autodesk usb stick to that folder, tried loading Inventor file again - still didnt work.
Thanks for the try though.
I have the same problem that You..
Someone have solution of this error ??
I do everything that You write on this post but I have still this problem :(:(
hashim.mundol
Have you installed Directx manually without any errors ?
Hashim Mundol
Administrator Productivity
