Just installed Inventor PDS 2012 and when trying to open a file or start a new file in Inventor - I get "Serious Error - Library c:\program files\autodesk\inventor 2012\bin\d3dx9_42.dll does not exist" - Then Inventor crashes.
I found the d3dx9_42.dll file on the USB stick and copied it in the file listed above, rebooted - and still same problem.
Any suggestions much appreciated
Jim
Please install directx from the MS site or from the media
http://www.microsoft.com/download/en/details.aspx?id=35
http://www.microsoft.com/download/en/details.aspx?id=8109
I did the DirectX downloads, rebooted, and still same problem.
Didnt work.
Thanks Dazzman - That folder had the file in it, but it was a different size than the file supplied by Autodesk, so I copied the file from my new Autodesk usb stick to that folder, tried loading Inventor file again - still didnt work.
Thanks for the try though.
I have the same problem that You..
Someone have solution of this error ??
I do everything that You write on this post but I have still this problem :(:(
Have you installed Directx manually without any errors ?
