Installation & Licensing
730 Views, 3 Replies
Serial Number
Just brought a book introducing Maya 8 3D for Beginners need serial number for the cd which came with the book
3 REPLIES 3
david.lau
Maya 8 PLE doesn't really have a serial number. It does have a 'code' that will allow you to install it. This should be on the read me file or in the book.
Which version are is the Maya PLE? 8.0 or 8.5
Just an FYI - Maya 2010 doesn't have a PLE version. It is a 30 day trial. Edited by: subpartner_laud on Mar 26, 2010 7:51 AM
David Lau
sahu.mukesh85
In autodesk3dsmax 2010 trialversion registration problem is in the forum of Product Registration & Activation.
It shows in Enter Product Serial Number that "the serial number you entered is not valid.Try again(Error 2,12 etc).
but the serial number of this product is 000-00000000
TravisNave
All zeroes will allow you to install the product and run as a trial, however you cannot activate a trial version. You will need to purchase a valid license to activate the product beyond the trial.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
