• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Nehls, Kevin
    Separating licenses with AdLM???
    90 Views, 2 Replies
    05-10-2000 08:40 AM
    Can you separate out licenses with AdLM? I have 10 licenses and I want to
    make sure that one department can ALWAYS have 4 of those while another
    department ALWAYS has the other 6. Is this possible to do with one AdLM
    server?
    Kevin Nehls
    remove -ns- for direct reply
    Please use plain text.
    *milana, jerry
    Re: Separating licenses with AdLM???
    05-10-2000 03:47 PM in reply to: *Nehls, Kevin
    Kevin,
    You can do this IF you are using the TCP/IP AdLM on a Windows system. See
    http://www3.autodesk.com/adsk/support/techdoc/0,,154338--123737-0_21841,00.h
    tml for an explanation of the Resource File Feature of AdLM.
    The IPX (Netware) version of AdLM does not offer this feature or
    functionality.
    Jerry Milana,
    Autodesk Product Support
    "Kevin Nehls" wrote in message
    news:ef06b4a.-1@WebX.SaUCah8kaAW...
    > server?
    > Kevin Nehls
    *Nehls, Kevin
    Re:
    05-10-2000 04:26 PM in reply to: *Nehls, Kevin
    I guess I should have looked in the documentation, now I remember reading
    about it.
    Thanks Jerry. :smileyhappy:
    BTW, we are running TCP/IP on Windows systems, so it will be perfect.
    Kevin Nehls
    jerry milana wrote in message ...
    Kevin,
    functionality.
    Jerry Milana,
    > server?
    > Kevin Nehls
