Which software I should use for stress analysis simulation?
I was using Autodesk Inventor Professional 2012 for stress analysis because it was installed in my work place. Now we got the 2013 update and need to know that which one we should use as there are lot of Autodesk product released. Or the one we will get after Autodesk Product Design Suite Ultimate 2013 installation will be the appropiate one to use in future?
Thanks in advance.
Solved by dave.anderson. Go to Solution.
Depending on the level of Product Design Suite you have, you can keep using Inventor Pro. Inventor Professional comes in the Ultimate version of Product Design Suite.
If you need more than it provides, we have additional Simulation products:http://usa.autodesk.com/simulation-software/ that would not be part of your Suite.
