I recently downloaded a student version of Autodesk Autocad Architecture 2014 and it ran without any issues on my new Windows 8 laptop. However due to other problems with the laptop I needed to reset the system and therefore needed to reinstall the programme. The reinstallation worked but once I attempted to start Autocad I encountered the following error message "The security system (Softlock license manager) is not functioning or is improperly installed". I've read through many online discussions which advise on how to resolve the issue, such as dealing with the FlexNet service or attempting a full reinstall on more than 2 occasions, however none of these have seemed to resolve the issue. I was hoping that someone could help me in finding a solution to this very irritating problem.
Solved by p.j.luddy. Go to Solution.
Uninstall the software and re-install it. I would use a BROWSER Download of the software. Once the file is downloaded, I would rename C:\Autodesk to C:\Autodesk2 before extracting it.
Hello. Have you tried to delete the TSF.data file?
It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
Find this file and change the extension to something different, like ADSKFLEX_NUMBERS_TSF.data.BAK or completely move it from this folder. We don’t want to destroy it, just get it out of the way.
After it is moved or renamed, start the program. A new TSF DATA file will be created and possibly a log file. If the program now works, great, if not, delete the NEW TSF.DATA file and the log and place the original file back in this location, or rename back to ADSKFLEX_NUMBERS_TSF.data
Now try to start the program. If you are asked to register, do so and you should be set.
Thank you for taking part in our community!
Hi, first of all, thank you for your help. I had attempted both these solutions before but neither worked, however after your response I decided to give it another go and reinstalled the programme. Once again it did not work as the "Security system / Softlock license manager error" popped up, so i tried dealing with the FlexNet files and that didn't work either. I am still very confused as to how this keeps happening. Should I try to install the standard AutoCad programme and see if that works? Any further solutions or advice would be extremely helpful.
Today I spotted the solution to my problem on another thread ( http://forums.autodesk.com/t5/Installation-Licensing/softlock-license-manger-error-message/td-p/3002... )
It seems that all you have to do is:
1) Close any running applications or files or internet browsers
2) Cut the actual "FLEXnet" file ( found at C:\ProgramData )
3) Paste this file onto your desktop
4) Startup AutoCad and it should be running without issue
Thanks again for your help and in turn I hope this can solve this irriatating problem for anyone else who may be struggling with it.
i am using autocad 2013 and it was working with windows 8. I installed in compatibility mode
when i upgraded to windows 8.1, autocad 2013 failed to open...it shows 'softlock license manager error'
i tried to reinstall the autocad 2013 but i got the same error...please help
Dear Sir,
In win8.1 I got trouble to open AutoCAD Civil3D 2014, like "The security system (Softlock license manager) is not functioning or is improperly installed".
I tried all of the recommendations. None of them work.
Please, I seriously need that.
thank you.
Hi Guys!
I have recently installed windows 8.1 and the solution doesnt work.
Does one anyone have a new solution for this problem? I am using AutoCad2014
Take care
I have windows 8 and autocad 2013.
I deleted the log file and after this turn on FLEX services and it's working after computer restart.
thanks
Would you believe I have the same problem with the softlock licence manager.
Installed educational version of Autocad 2016 running on windows 10 - 32 bit. Educational version of Inventor 2015 works fine on the same machine.
I've tried all the steps tricks and tips I can find; deleting/removing the flexnet folder and files, flexnet service running (tried stopping and starting it.
Uninstalled - clean reinstalled, virus off, UAC off, installed and run as admin, still no luck.
I must say the security on this version is very good. Odd that inventor runs fine - I'm about to give up ...
Any other suggestions.
