Installation & Licensing
maxxlab
277 Views, 4 Replies
Saving Files
I have recently started noticing that when saving my file, it is creating 2 extra files, an atmp file and a sav****.tmp file into the same directory as my dwg.  Each atmp and sav****.tmp file is the same file size as my actual dwg and sometimes slightly larger.  How do I stop this from happening?
4 REPLIES 4
pendean
in reply to: maxxlab
AutoCAD is being prevented from deleting, renaming and adding new files: what did you change recently? Where are you saving your files? This is a system level problem.
AutoCAD's QSAVE does the following:
Saves to TMP file
deletes the old BAK file
Renames the DWG to BAK
Renames the TMP to DWG
ATMP is created if the TMP filoe is present.
maxxlab
in reply to: pendean
I haven't changed anything. It just started a couple weeks ago. My files
are all saved to my companies network drive.
Is there a variable I could have typed that turns on or off the tmp file
creation??
catalyst
Jim Klimek
Engineering
email: jklimek@catalystexhibit.com
7809 100th Street
Pleasant Prairie, WI. 53158
Direct 262.764.5377
Main 262.764.5454
Fax 262.764.5455
www.catalystexhibit.com
www.catalystexhibit.com/portfolio
Chicago . Amsterdam . Shanghai
pendean
No 'variable', something on your network drive is stopping AutoCAD from performing the functions I noted in my last reply.
Engage your I.T./network Administrator, there is no fix inside AutoCAD. Sorry.
Sergio.Bertino
Please have a look also to our TS for additional information regarding temp save files:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8227674&linkID=9240617
Sergio Bertino
MFG Technical Support Specialist
Administrator Productivity
