• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Schmidt, John
    Save problem with Novell 5
    118 Views, 7 Replies
    10-08-1999 09:38 AM
    One of our customers is running approx 12 stand-alone versions of
    AutoCAD, both R14 and R2000. They typically store their drawings on a
    Novell file server. When they were on Novell 4, there were no problems,
    but since moving to Novell 5, the first time they try to save, it says
    the drawing is open, and saves under an .ac$ filename, but then if they
    try it a second time, it will usually save normally. This usually
    happens whether they do the save-save immediately or wait 10 minutes in
    between; it seems that every other save is saying the drawing is still
    open.
    Has anyone else seen this with Novell 5? They claim to have absolutely
    the latest of everything from Novell installed.
    Thanks for any info,
    John
    Please use plain text.
    *Flores, James K
    Re: Save problem with Novell 5
    12-09-1999 12:21 PM in reply to: *Schmidt, John
    We also are having problems w/ Novell 5 and Autocad. Before our upgrade to
    Novell 5, Autocad worked fine, now, we need to "recover" most drawing we
    want to work on. If we are lucky, they recover fine, if not, we have to
    retrieve them from our tape backup. One of our latest and greatest errors
    was received just today from one of our release 13 seats "Internal Error:
    !dbvtx.cc@ 296:ePermanentlyErased" . Now whats that all about? Let me know
    if you get anything.
    John Schmidt wrote in message
    news:37FE1E0B.A9180451@aectech.com...
    > open.
    > John
    *Read, Barry
    Re:
    12-14-1999 07:03 AM in reply to: *Schmidt, John
    James:
    We have been having the same problem since switching to Novell 5 from Novell
    4.1. We are having a lot of problems with files being corrupted and having to
    recover them. Some times we are unable to recover the file and have to go to a
    previous backup....obviously we lose any changes that were made recently. We
    are running Windows NT 4.0 on the desktop. Does anyone have any ideas? This is
    really getting frustrating.
    Barry
    > > open.
    > > John
    *Gilmer, Tom
    Re:
    12-14-1999 07:49 AM in reply to: *Schmidt, John
    I switched our office from NetWare 4.10 to NW 5 on June 1, 1999 and have not
    had any problems. My suggestion is to make sure all NT Workstations are
    running NetWare Client for NT Version 4.60.SP2.
    You can get the latest clients from
    http://support.novell.com/misc/patlst.htm
    Hope this helps
    - Tom
    Barry Read wrote in message <38565C5A.F47E7352@komatsu-inc.com>...
    >James:
    Novell
    to
    to a
    We
    This is
    *Read, Barry
    Re:
    12-14-1999 09:13 AM in reply to: *Schmidt, John
    Tom:
    Thanks for your response. Yes we are running NT Client 4.60 Service Pack 2.
    Barry
    "Tom Gilmer" wrote:
    > Hi,
    > Hope this helps
    > - Tom
    > >James:
    > Novell
    > to
    > to a
    > We
    > This is
    *Gilmer, Tom
    Re:
    12-14-1999 09:59 AM in reply to: *Schmidt, John
    Barry,
    There are network issues relative to AutoCad's partial save mechanism. I
    believe that file corruption can occur when partial saves are executed over
    a network. I have set ISAVEPERCENT system variable to 0 (zero) on all my
    machines. This forces each save to be a full save. We have no corruption
    problems during the 6 months on NW 5. It might be worth a try.
    - Tom
    Barry Read wrote in message <38567AA9.4A2BA628@komatsu-inc.com>...
    >Tom:
    2.
    >Barry
    *Flores, James K
    Re:
    12-15-1999 06:11 AM in reply to: *Schmidt, John
    When you talk about the ISAVEPERCENT variable, do you mean you added that
    option under the control panal\system properties\environment area?
    wrote in message news:8360ji$e9c22@adesknews2.autodesk.com...
    > Barry,
    over
    > - Tom
    > >Tom:
    > 2.
    > >Barry
    *Gilmer, Tom
    Re:
    12-15-1999 07:20 AM in reply to: *Schmidt, John
    No! At the Acad command line type ISAVEPERCENT. It's probably set to 50. Set
    it to 0 (zero) to force every save to be a full save.
    Alternately, you can type preferences at the command line to bring up the
    Preferences/Options dialog box. In R14, select the Performance tab. For
    R2000, it's called Open and Save. The incremental save percentage shows the
    current setting. Click on Help to get an explanation.
    Good Luck,
    - Tom
    James K Flores wrote in message <8387n1$igt19@adesknews2.autodesk.com>...
