You are having problems with:
Solved by brian.kling. Go to Solution.
I had an on-line chat with a REVIT rep. - he indicated that my product was automatically registered. Great news.
Hi @jtfowler3 and welcome to the Autodesk Community!
It sounds like your product has been activated but you can check under Help > About. Or you can determine the serial number through licpath.lic. If you find your serial number in one of these locations your product has been activated. If not, you will be prompted to activate upon opening your product next.
Hopefully this helps! If you have any other questions please respond to this post. Thank you!
Thanks Jessica. The AutoDesk On-Line chat representitive guided me to the information and confirmed my activation. Great service & I'm I'm anxious to explore Revit 2015
You're welcome, @jtfowler3! I'm glad you got it all worked out!
I will need revit 2014 product serial number & autocad 2014 product serial number
THANK YOU
Hi @singhjaspal991,
Please visit the Education Community so that you can register for Revit 2014. If you have any questions please reply to this post. Thanks!
My Product Key is not working. I enter it right but the program answers there is something wrong in it. What should I do now? I've attached the printscreens.
I checked it out, it's ok:
Please be aware that this is a public forum posting serial numbers or personal information is not advise
Edited by
Discussion_Admin
Hi,a litle patience,for me was same,but I wating 2-3 days end got rite serial num.
Hi @qiwi0bird,
Did you by chance try typing in the code instead of copying and pasting? That often times helps, as trivial as it sounds. Also, do you have any other Autodesk products installed on this machine? Sometimes new activations pull in old licensing. If that's the case you may want to try uninstalling and re-installing.
If the problem persists please contact the Activation and Registration department for direct licensing assistance:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
Please reply to this post with any other questions or concerns. Thanks!
Pretty recently i have started a game design course in Melbourne Australia, and upon starting the course i had to get codes for your products, due to unfortunate circumstances i no longer have any liscences left, so i applied for a new one. upon receiving said Liscence code I have tried multiple ways but cannot find a place to input the 56 digit activation code i was given. if you could let me know where to put this code and maybe even update the email you recive upon getting the code to let you know in a bit more detail where the code goes. thank you so much for your time and ai hope you take this into consideration, i hope to hear from you soon.
Ryan O'Connor
I got an installation for 3ds Max from the Autodesk website. However I can't use the code I was given: My serial number isn't marked wrong, however my product key generates the error : "The product key entered is not valid. Verify and re-enter it". I have tried using the keys several times now over the course of the 30 day trial version, but it never worked. I have registered 3Ds Max on the autodesk website and rechieved an activation code. But I don't now how it will help me, since on the activation display there is no place to put it.
Please reply, I really need the software 🙂
Hello @eva.kaup!
Can you please confirm that your product key matches up with what's listed for the product below?
2015: Product keys for Autodesk products
2014: Product keys for Autodesk products
2013: Product keys for Autodesk products
How to find the Serial Number and Product Key for your Autodesk product
If so and you're still experiencing issues, can you then contact our License Assistance Team for direct activation support.
To find self-service solutions or reach us via Chat for Activation and Licensing Help:
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
Good morning,
sorry for write to you in another discusion but i need to activate my Autocad 2015 and Revit 2015 and always i try this error appears:
"Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems.
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days."
Can you help me with the activation of both programs? I don't understand why always the option of online activation never works, always resend instantly this error
Thank's you.
Pd: I've already done the manual activation and I have an Autodesk activation code, but the error persist when I try it manually.
Hi @sa.gomez774 and welcome to the Autodesk Community!
Can you please try disabling your firewall and anti-virus programs and try entering the activation code again?
Let me know if this works, please.
The activation code is not working for autocad and gives me the following error message:
Registration-Activation Error (0015.111)
There is a problem with the activation code that you entered. Click one of the following links.
I had a hardrive failure and needed to reinstall autocad (student version)
I have now received a new activation code from autodesk twice but both
give me the same error message.
this is my request code:
6FXG 8JCF 1YUX 5DWA C29V Y2T9 TDD3 EWVZ
what do I have to do?
Hi @annabelle_guldner and welcome to the Autodesk Community!
For direct licensing assistance, please contact our Activation and Registration department with your serial number, request code, and the product / version that you are trying to activate:
If you have any other questions or concerns please reply to this email. Thank you!
I have downloaded AUTODESK 3ds max and when I try to use my product key and serial number to activate my liscence, it says
The product key entered is not valid. Verify and re-enter it.
I have checked and I know that that is the correct product key I was given for my "Educational Master Suite 2015 Multi-seat Stand alone"
Hello NSchaff,
Welcome to our forums.
I have checked your license details. As your serial number corresponds to Autodesk 3ds Max 2015 and not to Autodesk Education Master Suite 2015, please make sure that you use the Product Key for 3ds Max and not the Product Key fot the Suite. The Product Key for Autodesk 3ds Max 2015 is 128G1.
You can find the list of Product Keys for our products on our website:
Kind regards,
My code doesn't work! What should I do? I don't know how to generate a new code. My License is a Students' License. SOS
