You are having problems with:
Solved by brian.kling. Go to Solution.
Please send me a PM (click on t_gaisf profile name and then Send this User a Private Message) with your Serial Number, the request code and confirm the registered name
or contact our licence assistance team for direct support.
Hi!
I've downloaded and installed the free student's version of Maya 2013 but my serial number/key don't work. now it's already 30 days and I cannot use it anymore because my "lecense is expired". i've tried to send to autodesk this information but never got an answer, tryed also to reinstalle or to delete and redownload and reinstall it but it doesn't work because of the same reason. can you help me please? I need Maya too much for my lessons of 3D. Thank you! my e-mail is: barrow88@mail.ru
Daria
Hi Daria!
The Registration and Activation team has received your case through the Licensing Assistance form.
Thank you!
can you help me solve my issue with this error 20. im pretty sure you know what error im talking about but if not ill explain when you respond but im looking for someone who can help me and figure this out but it seems very impossiable. thank you so much please repond.
Hi Thomas,
What program are we talking about and on what Od are you running it?
Are there any additional error messages or do you just see an Error 20?
Thank you,
I registered, I recieved a product key but when I enter the product key in the installion prompt, it says it's invalid. What can I do
I downloaded maya 2011 for my mac and i tried to input the seriel number given and it returned invalid...what do i do? please help as this is critical!
Tom
Hello 1100745 and welcome to our Forum,
If the product is match with the serial number and product key , it will be install and activate successfully.
Could you please check the installer you have downloaded is Maya 2011 for Mac and match with your serial number? if not, you could re-download it from here.
If you confirm the installer and serial number match, but it still be prompt invalid serial number when you activate the product, please feel free to send me a Private Message (click on my grace.liu profile name and then “Send this user a private message”) with your Serial Number,Product Key,and your registration details , I will help to check.
I just downloaded Student Autocad 2011 for mac. It says The Serial Number or Product Key don't Match. I was reading the forum but all the replys are from 2011 and couldnt find any solutions. Do you know how to solve this problem?
Merve
HI,
I am trying to get AutoCAD 2011 for mac (student), but my serial number and product key do not match. I have checked every single thing I could to make sure both numbers I was given were correct, and they are. What am I supposed to do from here?
p.s. I noticed that someone else had the same exact problem with the same program, so this must be a common problem right now
Thank you for the advise, but it did not solve my problen. Luckily, I found a way to make it work, here are the steps for that other person who has the same problem: (my terms may be incorrect, I am not tech person)
1) In the area where you can enter the serial number and code, don't. Pick the "trial" button and finish installing.
2) When it is installed, pick the CADD icon to open it
3) when open, there should be a page telling you that it is a 30 trial. The bottom left is a button that says "try", the bottom right has a button that says "activate". Pick "activate".
4) This new page has a place to put in the serial number and product code. Enter both and continue.
It should now be completely activated. For me, a messege came up saying something about it printing with words saying that it was from a student verion, or something like that. I hope this helps other people 🙂
I need the serial number and product key for AUTOCAD 2012. I download the Mac version. I am a student in Houston, Texas. HELP
Maritsa Rosa
Hello Maritsa and welcome to the Autodesk Community!
Have you registered at our Education Community yet? There you can access free student licenses that last for three years.
Please let me know if you have any troubles doing this.
Thanks!
I was able to download through the download link just 2 days ago but now the pop up thing doesn't appear anymore. Reply please, ASAP!! I need to finish my work within today but my autocad 2014 got deleted and now using another laptop
Hi Kathleen,
I believe you have your Serial # with you and you just need the Download link, correct? If so, for the AutoCAD 2014 you can download it from our Trial Version page or Matt, Our Virtual Agent.
After downloading the software just proceed with the Activation. If you need further assistance, feel free to contact our Registration and Activation team.
Hi, Im trying to run Autodesk Simulation CFD and in order for me to get a license, I need to either: acivate it on the Product Registtration & Activation, which tells me that my serial number is not valid (see attatchment), or go to Services & Support which asks me for a Request Code that I dont seem to have. After trying to find this request code at the "How to find your request code" in the Autodesk AutoCAD Services and Support section, I could not find the file at the described location. Please advise.
