Installation & Licensing
STUDENTS - Serial Number or Product Key Issues
1,173 REPLIES 1,173
Message 1 of 1,174
brian.kling
114835 Views, 1173 Replies
You are having problems with:
  • Getting a Serial Number or Product Key
  • Your 30 day trial is about to expire
  • Your 30 day trial has expired and you can't get a serial number
See the Solution in the Reply below!
Brian Kling
Sr International Customer Experience Lead
Autodesk, Inc.
1,173 REPLIES 1,173
Message 641 of 1,174
in reply to: philip.s
While trying to download "AutoCAD Electrical (English) 64-Bit" I keep getting an error:  "Error assigning serial number to product: ~HASH(0x15a337d0)->{'Body'}->{'Fault'}->{'faultstring'}"
The Product Serial Number provided is invalid.
I would appreciate any help considering the problem above.
Thank you in advance,
Damir Mirkovic
Message 642 of 1,174
philip.s
Hello Damir,
We greatly apologize for the inconvenience, and are investigating the root cause of this issue.
With that being said, you can either utilize the software in it's trial mode for the time being, obtain a free student license from the Students Facebook page, or create a new Education Community profile using a different email address (as this is tied to your current account and is not system wide).
Message 643 of 1,174
tracy.wheeler
in reply to: brian.kling
Need activation code
Regarding CaseNo:07880239
V98D 5298 ADF8 A353 ARUX E42R CKT3
Message 644 of 1,174
Hi tracy.wheeler and welcome to the forums!
It seems that your Inventor Suite 2009 has been activated by our registration and activations team. In any case, I have sent you the activation code via private message here on the forums (click on the envelope by your name at the top of the screen).
Camilo Lemos
Message 645 of 1,174
Hey,
I am having the same problem as some of you here, with activating the AutoCad Mac 2013 English download.
when i enter my Serial Number and Product Key, i get this message saying it wont work.
The Serial Number or Product Key don't Match.
Valid format for serial number is (XXX-XXXXXXXX)
Please Help.
Luci
Message 646 of 1,174
joane.bonghanoy
Hi Luci,
Sorry for the trouble this has caused you.
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code
Joane Bonghanoy
Message 647 of 1,174
I have the same problem.Smiley Frustrated
I'm in Taiwan.
But finally the installation display "Your product cannot be registered in Taiwan."
Why? Something wrong?
Message 648 of 1,174
joane.bonghanoy
Hi Avonyu,
Looking forward to your reply so I can get this sorted out right away.
Joane Bonghanoy
Message 649 of 1,174
I downloaded Revit Architecture v2011 on my laptop and I can't activate the license ! So I had about 20 days with a test version (i could save my work and all), but now this period is over, and I still can't activate the license ! When I choose "repair" in the window that tells me to activate the license, I get that strange new window :
Two options, it seems, and whatever I choose, even pressing "enter", nothing happens.
I precise I had downloaded an Autodesk program yet, Autocad v2011, and i had no problem activating the license.
Someone help me ? 😞
Thanks in advance !
Kevin.
Message 650 of 1,174
Hello Kevin,
The blank activation screen error is a know issue with documented troubleshooting steps. Please check out the solution here, on our Pinterest page and let us know if you have any additional questions, concerns, or issues.
Message 651 of 1,174
I'm in Taiwan.
Please tell me why the product can't be registered in Taiwan.
Message 652 of 1,174
Mine is saying serial key and product key do not match. Can anyone help me?
Message 653 of 1,174
it's on mac
Message 654 of 1,174
philip.s
Hello Avonyu,
It doesn't look like you've requested a license yet from the Education Community. Did you obtain one elsewhere? If so, can you please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with the Serial Number so that I can investigate accordingly.
Message 655 of 1,174
philip.s
Hi Kyle,
What happens if you install in trial mode and then proceed with the standard activation process upon opening the program?
Message 656 of 1,174
After installing 2013 simulation CFD on windows 7 64-bit as a standalone installation it will not load up.  The FLEXnet License Finder pops up and no matter what option I select, whether my firewall is off or on, ... It will not load up.  The list of error codes I found does not include either of the ones I am getting nor did the search turn up any specific results for those codes. I have also reinstalled the software to no avail.   Any help would be appreciated.
when trying to specify license server system (-10.15.10061)
when trying to specify license file (-3.278.0)
Message 657 of 1,174
I figured it out on my own.  had to run the program in windows 7 compatibility mode on a windows 7 machine lol
Message 658 of 1,174
Hi all,
I spent 8 hours in trying to activate my student version of Autodesk Inventor Professional 2013 (German).
The problem  I am fighting with is that the activation page just shows the "known" two radio buttons and nothing more.
I have tried all the things which have been mentioned here
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
but none of this solutions is working.....
Also re-installing the software doesn't help.
Is there another way to get the software activated??
Thanks.
Best regards,
Tobias Tischler
Message 659 of 1,174
camilo.lemos
Hi Tobias and welcome to our community!
I've just had a look at your software activations and it looks like your Inventor Pro 2013 has just been successfully activated. Can you please confirm whether your software is not up and running?
Thank you.
Camilo Lemos
Message 660 of 1,174
in reply to: camilo.lemos
Hi Camilo,
thanks for the fast reply but the software is still running as a Trail-version. The serial number is starting with xxx-xxxxxxxx.
And the activation is still showing a blank page.
Best regards,
Tobias
Administrator Productivity
