Installation & Licensing
Member
c-kharper
Message 1 of 7 (311 Views)
STUDENTS - MAYA & MAX .dll isn't compatible
311 Views, 6 Replies
03-12-2013 09:00 AM
Ok so I get this error when I load Max or any other Autodesk product after installing (I've installed all types 2011/12/13)
'C:\Windows\system32\d3dx9_42.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support'
I've reinstalled way too many times now and I've done clean installations too. I'm not on a network and I am the administrator for my PC. I have a quad core AMD processor with a 1GB graphics card and 8GB of RAM so it's above the minimum system requirements. I'm running a 64-bit of Windows 7 Home Premium if that also helps.
Has anybody else had this problem or know how to solve it?
Cheers,
- Kai
TravisNave
Message 2 of 7 (305 Views)
Re: STUDENTS - MAYA & MAX .dll isn't compatible
03-12-2013 09:18 AM in reply to: c-kharper
It's probably as simple as updating your Microsoft DirectX runtimes.
http://support.microsoft.com/kb/179113
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
c-kharper
Message 3 of 7 (301 Views)
03-12-2013 09:23 AM in reply to: TravisNave
I did the download and I have the latest runtime of DirectX. Is there anything else you can recommend please?
Cheers,
- Kai
TravisNave
Message 4 of 7 (297 Views)
03-12-2013 09:29 AM in reply to: c-kharper
Yes.  Go to C:\Windows\System32 and locate the d3dx9_42.dll file.  Rename the extension to .bak.  Then try launching the application again.  Windows 7 does not use DirectX 9.
Member
c-kharper
Message 5 of 7 (294 Views)
03-12-2013 09:33 AM in reply to: TravisNave
Now it's coming up with this message:
'The program can't start because d3dx9_42.dll is missing from your computer. Try reinstalling the program to fix this problem.'
Shall I reinstall and see if that solves it?
Cheers,
- Kai
TravisNave
Message 6 of 7 (285 Views)
03-12-2013 09:39 AM in reply to: c-kharper
Yes.  Now would be the time to do so.  Let me know the results.
TravisNave
Message 7 of 7 (284 Views)
03-12-2013 09:44 AM in reply to: TravisNave
Just in case, here is the file from one of my Windows 7 computers that was installed with Autodesk software.  Unzip and copy into your System32 folder.  It might work for ya.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
