Installation & Licensing
New Member
tmward
Message 1 of 3 (2,941 Views)
STARTUP ERROR: 3DS MAX APPLICATION HAS STOPPED WORKING
2941 Views, 2 Replies
02-15-2012 10:55 AM
I've recently tried to start 3DS MAX and I get the following error:
3DS MAX APPLICATION HAS STOPPED WORKING. A problem caused the ogram to stop working correctly. Windows will now close the program (SEE SCREENSHOT) The program startup screen then closes.
I have tried re-installing the programming but to no avail. Help!
New Member
Message 2 of 3 (2,604 Views)
Re: STARTUP ERROR: 3DS MAX APPLICATION HAS STOPPED WORKING
04-07-2012 07:20 AM in reply to: tmward
Were you ever able to find a solution to this problem?  The same thing has happened to me and it couldn't be at a worse time.  This has happened once before (also at a very critical time) and the solution was for Autodesk to basically blow away my old serial number and product key, then assign me new ones.
I hope that this doesn't keep happening every 3 or 4 months.  It's kind of a deal-breaker...
New Member
Message 3 of 3 (2,465 Views)
05-07-2012 01:31 AM in reply to: nonlinearcreative
This seems to be similiar to our case: re-installing is not helping. Same error. The application crashes just before it starts to draw the viewport graphics (grid lines). In that respect it might refer to some kind of graphics problem, but if the replaced serials helped, then we are a bit puzzled. We run floating network licenses.
BR Tomas
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
