Installation & Licensing
Valued Contributor
gearknox
Message 1 of 5 (135 Views)
START IN TEMPLATE
135 Views, 4 Replies
11-18-2012 11:36 AM
I want 2013 to start using my template so I added the link to the template file to the "Start In"  file of the Properties using  -    C:\ENGINEERING\AGM\AGM 3D TEMPLATE 1 .DWT but that does not seem to work.
What am I doing wrong?
Bob Price
pendean
Message 2 of 5 (129 Views)
Re: START IN TEMPLATE
11-18-2012 12:26 PM in reply to: gearknox
"Start In" is a folder location, you appear to want "Start WIth" which is not there.
Look up the topic "About Customizing Startup" in 2013's help, or use this link for the correct procedure (hint: \t option):
http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-79ba...
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
gearknox
Message 3 of 5 (121 Views)
11-18-2012 01:11 PM in reply to: pendean
Thanks for the prompt reply - I thought I had the string starting with a file location - i.e. C:/Engineering/AGM Are you saying that I need to add the /t at the end of the string?
pendean
Message 4 of 5 (118 Views)
11-18-2012 02:17 PM in reply to: gearknox
Are you trying to avoid looking it up in HELP in 2013, or were the instructions not clear? Help me understand your follow-up query.
If you did not get a chance to look at it, HELP suggests:
To Start the Program With a Command Line Switch
1.Right-click the program icon on the Windows desktop and select Properties.
2.In the product's Properties dialog box, Shortcut tab, in the Target box, append the parameters for the switch using the following syntax:
"drive:smileytongue:athname/[product].exe/" ["drawing name"] [/switch "name"]
This should translate to something like:
"C:\Program Files\Autodesk\AutoCAD 2013\acad.exe" /t "YourDrive:\YourFolder\YourTemplateFileName"
Notice that nothing is being edited in the "Start In" line.
Valued Contributor
gearknox
Message 5 of 5 (115 Views)
11-18-2012 03:04 PM in reply to: pendean
Nope - not trying to be thick about this but I have laboriously attempted to get the string typed in correctly several times and had nosuccess. My wife is pestering me to come eat dinnerso I will try again in an hour. Thanks very much for the help. Bob Price
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
