Yes !
Saludos, Jorge Jimenez, SICAD S.A., Costa Rica
"jason martin" wrote in message
news:0023FDAC2723F90D99AC55C6B8D493D6@in.WebX.maYIadrTaRb...
> Jorge -
> Are you running Norton AV by chance?
> From Shaan Hurley
> > The 17.1.8 error code indicates that the license is in use by another
> > application. The most common reason for this problem is that a component
of
> > Symantec products is preventing the runtime system from initializing.
> > If you have any Symantec products installed, such as Norton AntiVirus®
> > version 5.02 or version 6.0 on Windows NT® 4.0, install the update for
the
> > Symantec Event Library Files (SYMEVNT). You can obtain the update at the
> > Symantec website.
> > (http://www.symantec.com/techsupp/files/symevnt/symevnt.html) Note: The
> > Readme file for this update is also on the Symantec FTP site.
> > Although the error code is different, solution number TS65112 should be
> > able to resolve your problem.
> > http://support.autodesk.com/getDoc.asp?id=TS65112
> jason martin
> frankfurt-short-bruza
> Member of the Autodesk Discussion Forum Moderator Program
> "Jorge Jimenez" wrote in message
news:1FDBAED26D58F5CFDFA6ED767E2F0943@in.WebX.maYIadrTaRb...
> > Hi,
> > We have AutoCAD Map2i running on Win2k, sp2
> > UDS is installed on it also.
> > The first time we launch Map2i everything works fine.
> > But if we close the application and later on open it again
> > we get the following error
> > "A License Error has occurred.Please restart your system to initialize
the
> > license management system.If this problem continues...."
> > Error: "18.1.78"
> > And Map will not load again until we reboot !
> > This is very annoying!
> > Please help
