• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    admamar
    SCCM distribution issues for Design Academy on win7x64
    182 Views, 3 Replies
    07-28-2011 03:28 AM
    Hi
    I have created Adminimage for most of the products on a server. SCCM installs them through network, with the setup.exe and the required command lines. Advertisement is per machine and scheduled. Evrything seems to work. But I have the following issues.
    Execpt Autocad, all other programs add desktop shortcuts(ie Inventor), In our organisation that is prohibited, I can probably remove them by editing the .mst files. But I was wondering if there is a way to do it in .ini? The same goes for Design Review and Inventor Fusion.
    Design Review shortcuts end up like:
    "C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Design Review 2012.lnk"
    "C:\Windows\SysWOW64\config\systemprofile\Desktop\Autodesk Design Review 2012.lnk"
    When i run msi+mst in system account with themsiexec and not using ALLUSERS property the shortcuts are ok ie
    "C:\Users\Public\Desktop\Autodesk Design Review 2012.lnk"
    Anyway to fix this in .ini?
    Please use plain text.
    Product Support
    Re: SCCM distribution issues for Design Academy on win7x64
    07-28-2011 01:13 PM in reply to: admamar
    Please try this
    http://images.autodesk.com/adsk/files/adr2012_install_guide.htm#DesktopShortcut
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
    New Member
    admamar
    07-28-2011 11:20 PM in reply to: hashim.mundol
    Thanks for the reply. I had read the article, but I am using Autocad Adminimage to distribute Design Review and did try the EXE_PARAM=. Maybe I should split the installation since the shortcuts also go to the wrong directory and are not available to users. Is msi+mst is enough or should i also include the gpo.mst for Design Review?
    How do i prevent desktop shortcuts for Inventor, Civil3d, Autocad Mechanical and all others?
    Product Support
    08-01-2011 01:28 AM in reply to: admamar
    I haven't tested these on the suite
    passing ADSK_DESKTOPSHORTCUT_1=0 to msi should work for all the products.
    gpo.mst is required only for gpo deployment
    Hashim Mundol
    Autodesk, Inc.
