Installation & Licensing
jlaidler
251 Views, 4 Replies
SAMreport Help
I can't seem to get SAMreport Lite to work.
I would like to run SAMreport from my computer, not on the server that runs the license manager.
The problem seems to be the report log generated by FLEXlm. Where is this located ??
4 REPLIES 4
in reply to: jlaidler
The report log is written to the file name and path you specify in the options file. See http://support.autodesk.com/getDoc.asp?id=TS66131 -- Jerry Milana, Autodesk Consulting "jclaidler" wrote in message news:11987730.1082721845526.JavaMail.jive@jiveforum1.autodesk.com... > I can't seem to get SAMreport Lite to work. > I would like to run SAMreport from my computer, not on the server that runs the license manager. > > The problem seems to be the report log generated by FLEXlm. Where is this located ??
jlaidler
So after creating "adskflex.opt" and putting "REPORTLOG +c:\test\report.rl" in it, restart the license manager??
After re-starting License Manager, "report.rl" will be created automatically ??
Yes, it FLEXlm will create it automatically, don't forget to store your adskflex.opt in the same folder as your license file. Regards, Efim "jclaidler" wrote in message news:18595524.1082739979217.JavaMail.jive@jiveforum1... > So after creating "adskflex.opt" and putting "REPORTLOG +c:\test\report.rl" in it, restart the license manager?? > > After re-starting License Manager, "report.rl" will be created automatically ??
jlaidler
Thanks... I'll give it a try.
Administrator Productivity
