I downloaded AutoCAD 2014 earlier tonight, and when I went to start the installer this error message came up instead. I have tried getting the newest 2010 C++ redis., Running windows update, Restarting PC, Running as admin, and a few other non-permanent changes and nothing has worked.
Windows 7 x64
Intel 3570k
8gb RAM
EVGA Nvidia GTX 670 2GB
600 gb HDD
60gb SSD
This is the first time I have seen this error. It's unfortunate that it happened to such powerful software. I'll be checking back regularly to see if there is any movement on this post.
Thanks!
Still seeking a solution.
Also, I booted in safe mode and was able to launch the installer. I didn't proceed to install, but the window actually opened without error.
I later went back and tried this, but windows installer doesn't run in safe mode nor does the driver for my graphics card. It told me that windows installer could not be launched and that my graphics driver needed to be updated before I could install.
Greatly appreciate the effort!
First of all restart the computer by pressing F8 before the windows logo appears.
Then select safe mode then press enter.
When your computer will start then click on start button and type msconfig in the program search box and press enter.
Open the msconfig program and then click the selective start up on the general tab and then click the load start up items. Then click the services tab then click hide all Microsoft services and then click disable all. For more details click here
Runtime error r6034 occurs when a file missing from your windows registry keys. If this error occurs then the chances of losing the information of the file which you are working increases.
Watch the given below instructions to fix it:-
Firstly try to keep proper maintenance of you windows registry.
Keep proper updates of windows.
Remove the software which makes this error to occur.
The best thing is to use third party repair tool which will easily fix runtime error r6034. And repair tool is also safe to use.
