I'm trying to install Autodesk Inventor and Mechanical Desktop 2004 DX through a domain server and using roaming profiles. With one of the roaming profiles the fatal error pops up:
FATAL ERROR: Invalid Configuration path\filename: C:\Documents and Settings\
\Local Settings\Application Data\Autodesk\\\enu\
I looked up the error on the knowledge base and installed the latest service pack as advised there. However, this does not resolve the issue. Please help.
Any help is appreciated.
