Installation & Licensing
New Member
jd239
Message 1 of 4 (345 Views)
Roaming Profiles and preventing "First Run" installation
345 Views, 3 Replies
02-18-2014 09:28 AM
I'm using roaming profiles for Autocad 2014 (network deployment) in a computer lab.  Things seem to be working but every time Autocad is launched on the computers it has to go through the very long "first run" installation.  I have copied the Autodesk folder from %userprofile%\AppData\Local up to the roaming profile on the network but I'm still having this happen.  Are there other files/folders that need to be copied to the roaming profile to get past this "first run" operation?
Product Support
asburyj
Message 2 of 4 (312 Views)
Re: Roaming Profiles and preventing "First Run" installation
02-18-2014 01:58 PM in reply to: jd239
AutoCAD writes into appdata local and appdata roaming and also access locations in the user profile folders like my pictures.You can find some details on this in the article linked below.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Seconda...
Jeffry Asbury
New Member
jd239
Message 3 of 4 (298 Views)
02-19-2014 04:03 AM in reply to: asburyj
"To resolve this issue, you need to disable the deletion of locally cached profiles for users who will be running the application."
So the Autodesk solution to the problem of roaming profiles is to not use roaming profiles?  Great...
Product Support
asburyj
Message 4 of 4 (289 Views)
02-19-2014 09:37 AM in reply to: jd239
Yes, unfortunately roaming profiles are not compatible with AutoCAD.
Jeffry Asbury
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
