"RobLewis" wrote in message
news:29534661.1093932880379.JavaMail.jive@jiveforum1.autodesk.com...
> We are running our network with Novell NDS management using roaming
profiles. Licensing for Autocad is managed by a microsoft based license
server. Distribution to our workstations uses Autodesk network deployment
from a Microsoft based server.
> The issue I am having is that every time Autocad 2005 is launched the
microsoft installer reinstalls the users profile 109mb onto the local
machine even though it is already there as the roaming profile put it back
when the user first logged into the workstation.
> The local distributor has been trying to help but to no avail.
> Has anyone else had this problem and how can we fix it I am sure a lot of
people use roaming profiles
Rob,
We have the same setup. We are a school, with 1200 different autocad users,
roaming all the time.
Well, I figured it out: I set all path that led to the users profile dir, to
a directory in his homedirectory on the network. This path is also in the
registry/autocad part, so you set it there to the right location. There I
copied all files
that were previously in the profiles.
And zenworks distributes these files at the first time the user starts
autocad.
Also some dirs, like the textures, are on a central place where users can't
change anything.
Haven't seen an installer since then.
Paul Minnaert,
