Installation & Licensing
New Member
rplosker
Message 1 of 4 (256 Views)
Revitt 2012 fails to install
256 Views, 3 Replies
12-15-2011 09:15 AM
Revitt 2012 fails to install and gives the following error:
I have uninstalled and reinstalled microft visual C++ 2005 and have got the same results
Machine
i7-2600 @ 3.4 ghz
windows seven pro
16 gigs ram
64 bit os
Please advise how we can fix this as this needs to be working this week.
Please Email: cteetaert@sepw.ca
2011/12/15:09:50:48 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:09:50:48 PC#5 PC5-PC Launch
2011/12/15:09:52:56 PC#5 PC5-PC === Setup ended ===
2011/12/15:09:50:54 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:09:50:54 PC#5 PC5-PC Launch
2011/12/15:09:52:56 PC#5 PC5-PC PageOpen LaunchDialog
2011/12/15:09:53:21 PC#5 PC5-PC PageOpen LicenseDialog
2011/12/15:09:53:24 PC#5 PC5-PC PageOpen ProductInfoDialog
2011/12/15:09:53:49 PC#5 PC5-PC PageOpen ProductSelectionDialog2
2011/12/15:09:53:56 PC#5 PC5-PC PageOpen FullProgressDialog
2011/12/15:09:53:56 PC#5 PC5-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PC#5\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/12/15:09:54:00 PC#5 PC5-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2011/12/15:09:54:05 PC#5 PC5-PC PageOpen InstallCompleteDialog
2011/12/15:09:54:47 PC#5 PC5-PC === Setup ended ===
2011/12/15:10:42:58 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:10:42:58 PC#5 PC5-PC Launch
2011/12/15:10:45:00 PC#5 PC5-PC === Setup ended ===
2011/12/15:10:43:04 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:10:43:04 PC#5 PC5-PC Launch
2011/12/15:10:45:00 PC#5 PC5-PC PageOpen LaunchDialog
2011/12/15:10:45:28 PC#5 PC5-PC PageOpen LicenseDialog
2011/12/15:10:45:33 PC#5 PC5-PC PageOpen ProductInfoDialog
2011/12/15:10:45:45 PC#5 PC5-PC PageOpen ProductSelectionDialog2
2011/12/15:10:45:54 PC#5 PC5-PC PageOpen FullProgressDialog
2011/12/15:10:45:54 PC#5 PC5-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PC#5\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/12/15:10:46:00 PC#5 PC5-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
*Expert Elite*
TravisNave
Message 2 of 4 (252 Views)
Re: Revitt 2012 fails to install
12-15-2011 10:33 AM in reply to: rplosker
The version you already have installed is probably a newer version of Microsoft Visual C++ 2005 Redistributable (x86) than the installer expects.  Use the Control Panel > Programs and Features to remove this version.  Reboot, then reinstall your Autodesk product.  It should install the version supplied and continue the installation.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
rplosker
Message 3 of 4 (248 Views)
12-15-2011 12:01 PM in reply to: rplosker
I uninstalled the visual 2005 (x86) and (x64) rebooted and I still get the same error as noted below.
Please advise.
Clifton
2011/12/15:13:47:43 PC#5 PC5-PC PageOpen InstallCompleteDialog   2011/12/15:13:50:25 PC#5 PC5-PC === Setup ended ===
2011/12/15:13:54:31 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 === 2011/12/15:13:54:31 PC#5 PC5-PC Launch 2011/12/15:13:56:32 PC#5 PC5-PC === Setup ended ===
2011/12/15:13:54:37 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 === 2011/12/15:13:54:37 PC#5 PC5-PC Launch 2011/12/15:13:56:33 PC#5 PC5-PC PageOpen LaunchDialog   2011/12/15:13:57:04 PC#5 PC5-PC PageOpen LicenseDialog   2011/12/15:13:57:08 PC#5 PC5-PC PageOpen ProductInfoDialog   2011/12/15:13:57:20 PC#5 PC5-PC PageOpen ProductSelectionDialog2   2011/12/15:13:57:32 PC#5 PC5-PC PageOpen FullProgressDialog   2011/12/15:13:57:32 PC#5 PC5-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PC#5\AppData\Local\Temp\vcredist_x86_2005.log"" " 2011/12/15:13:57:37 PC#5 PC5-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
*Expert Elite*
TravisNave
Message 4 of 4 (225 Views)
12-15-2011 02:44 PM in reply to: rplosker
Try installing the update direct from Microsoft then and see if it will install.  If so, the prerequisite should be skipped on Autodesk install.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
