Revitt 2012 fails to install and gives the following error:
I have uninstalled and reinstalled microft visual C++ 2005 and have got the same results
Machine
i7-2600 @ 3.4 ghz
windows seven pro
16 gigs ram
64 bit os
Please advise how we can fix this as this needs to be working this week.
Please Email: cteetaert@sepw.ca
2011/12/15:09:50:48 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:09:50:48 PC#5 PC5-PC Launch
2011/12/15:09:52:56 PC#5 PC5-PC === Setup ended ===
2011/12/15:09:50:54 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:09:50:54 PC#5 PC5-PC Launch
2011/12/15:09:52:56 PC#5 PC5-PC PageOpen LaunchDialog
2011/12/15:09:53:21 PC#5 PC5-PC PageOpen LicenseDialog
2011/12/15:09:53:24 PC#5 PC5-PC PageOpen ProductInfoDialog
2011/12/15:09:53:49 PC#5 PC5-PC PageOpen ProductSelectionDialog2
2011/12/15:09:53:56 PC#5 PC5-PC PageOpen FullProgressDialog
2011/12/15:09:53:56 PC#5 PC5-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PC#5\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/12/15:09:54:00 PC#5 PC5-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2011/12/15:09:54:05 PC#5 PC5-PC PageOpen InstallCompleteDialog
2011/12/15:09:54:47 PC#5 PC5-PC === Setup ended ===
2011/12/15:10:42:58 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:10:42:58 PC#5 PC5-PC Launch
2011/12/15:10:45:00 PC#5 PC5-PC === Setup ended ===
2011/12/15:10:43:04 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 ===
2011/12/15:10:43:04 PC#5 PC5-PC Launch
2011/12/15:10:45:00 PC#5 PC5-PC PageOpen LaunchDialog
2011/12/15:10:45:28 PC#5 PC5-PC PageOpen LicenseDialog
2011/12/15:10:45:33 PC#5 PC5-PC PageOpen ProductInfoDialog
2011/12/15:10:45:45 PC#5 PC5-PC PageOpen ProductSelectionDialog2
2011/12/15:10:45:54 PC#5 PC5-PC PageOpen FullProgressDialog
2011/12/15:10:45:54 PC#5 PC5-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PC#5\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/12/15:10:46:00 PC#5 PC5-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
The version you already have installed is probably a newer version of Microsoft Visual C++ 2005 Redistributable (x86) than the installer expects. Use the Control Panel > Programs and Features to remove this version. Reboot, then reinstall your Autodesk product. It should install the version supplied and continue the installation.
I uninstalled the visual 2005 (x86) and (x64) rebooted and I still get the same error as noted below.
Please advise.
Clifton
2011/12/15:13:47:43 PC#5 PC5-PC PageOpen InstallCompleteDialog 2011/12/15:13:50:25 PC#5 PC5-PC === Setup ended ===
2011/12/15:13:54:31 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 === 2011/12/15:13:54:31 PC#5 PC5-PC Launch 2011/12/15:13:56:32 PC#5 PC5-PC === Setup ended ===
2011/12/15:13:54:37 PC#5 PC5-PC === Setup started on PC5-PC by PC#5 === 2011/12/15:13:54:37 PC#5 PC5-PC Launch 2011/12/15:13:56:33 PC#5 PC5-PC PageOpen LaunchDialog 2011/12/15:13:57:04 PC#5 PC5-PC PageOpen LicenseDialog 2011/12/15:13:57:08 PC#5 PC5-PC PageOpen ProductInfoDialog 2011/12/15:13:57:20 PC#5 PC5-PC PageOpen ProductSelectionDialog2 2011/12/15:13:57:32 PC#5 PC5-PC PageOpen FullProgressDialog 2011/12/15:13:57:32 PC#5 PC5-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PC#5\AppData\Local\Temp\vcredist_x86_2005.log"" " 2011/12/15:13:57:37 PC#5 PC5-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Try installing the update direct from Microsoft then and see if it will install. If so, the prerequisite should be skipped on Autodesk install.
