Every time I try to install the student version of Revit Architecture 2011 on Windows XP Pro it extracts everything and then halts during setup with a message "Failed to copy files. The reason can be that either the disk is full or "...path.../temp/_AIAD.tmp" is not empty. Please delete "...path.../temp/_AIAD.tmp" and try again. I've tried shutting of antivirus, re-downloading the files, making sure the path has write permssion. So far nothing works. How can I get this to install?
