Installation & Licensing
Revit installation problem
5 REPLIES 5
calebg
487 Views, 5 Replies
Hey. I downloaded the online student version of Revit architecture last night and after it finished downloading I had some problems. It tells me the download is complete and gives me this link "Open Autodesk Revit Architecture 2012 (English) 32/64-Bit (1 of 1)" to open it. When I click on the link another window opens and says "
“5868a8f2762f6f90129dabf838e49a8863648b85” is a file which was downloaded from the internet. Are you sure you want to open it?" I have tryed all of the programs I have and none of them will open it. What do I open it with? Also it didnt let me choose where i wanted it downloaded
5 REPLIES 5
TravisNave
in reply to: calebg
Try addining .exe to the filename extension and then please post back the results for verification.
Autodesk Forums:
TH
Community Visitor
in reply to: TravisNave
I had the same problem with Navisworks.  I added .exe and the program started to install.
Thanks for the heads up!
TravisNave
in reply to: TH
Thanks for verifying that this works.  I had made this suggestion a few times recently and have yet to get confirmation on it.
Autodesk Forums:
silviaberian
Hi,  I have the same problem as the person that posted.
Where exactly to I add  .exe???    Do you mean by the file which was downloaded from the internet ?
Please help, i am at the end of my wits....
thanks
Silvia
TH
Community Visitor
in reply to: silviaberian
You can add the .exe to the file you downloaded or try this.
When you download the file the website give you a like to click.
When you click the link the compoter doen't know how to open the file.  Have your computer open the link with internet explorer.
Once I did that it went to the usuall download pop up that gives you the option to open/save/cancel.
Hopefully that will work for you too.
Administrator Productivity
